Stingray Forum (Read Only)
Welcome to Autodesk’s Stingray Forums. Share your knowledge, ask questions, and explore popular Stingray topics.
Not Importing 3DS Max Animation Clip
6 REPLIES 6
vlsheehan
430 Views, 6 Replies
I've created an animated flag in Max but Stingray is not importing the animated clip. The flag has 300 frames so is there a limit?
Below is a link to the Max file.
http://a360.co/2mIyBoU
Below is a link to the exported FBX file.
http://a360.co/2mICIRO
Here is the method I used in creating the flag with the exception of using the Garment Maker, I used a plane then divided it into 25x25.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
6 REPLIES 6
__ben__
in reply to: vlsheehan
Could you please post the FBX along with the dependencies? In particular when I try importing your FBX it is missing the file:
F:\Installs\AutoCAD Drawings\3D Civil View\materiallibraries\US-Flag.jpg
Perhaps when you prepare the FBX you can embed the textures?
The flag did import into Stingray however it was solid black since the texture was missing.
vlsheehan
in reply to: __ben__
I have read the keyframes created from a Cloth Modifer Simulation in 3DS Max are different than standard animation keyframes. The simulated keyframes are not exporting to FBX so this is not a Stingray issue. When/if I find a workaround, I'll post it.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
jpvangastel
The best approach in 3ds Max would be to use bones with splineIK and a SkinWrap modifier which is capable to transfer your cloth simulation onto the 3ds Max bones. Skin is exported with the animation to stingray.
JP van Gastel
Autodesk Media & Entertainment Specialist
JP van Gastel
Shanii2
You can also enable it as apex cloth, and the flag will animate procedurally inside the engine, as you would with other simulation
dave.tyner
in reply to: Shanii2
@Shanii2 Max does Apex cloth?
Shanii2
in reply to: dave.tyner
Yes it does,  installing proper nvidia plugin and there are tutorials on how to do apex cloth simulation for 3ds max and follow the workflow for importing in engine.
