I used the basic setup (non-vr) and added some cameras and some flow to switch between them using the keyboard. Worked great. I now want to do the same thing in the htc vive setup.
Normal teleportation should still work but if I tap a key on the keyboard move me to a new position and forward direction. I am unable to find the vr camera to try to do anything to it.
Thank you
Solved by paul.kind. Go to Solution.
Solved by svaisanen. Go to Solution.
Look for the Steam VR/Steam VR Set Tracking Space Flow node.
You can find an example of this being used in the VIVE template, open the wand_extras_1 unit in the unit editor and go into the Unit Flow.
You can check out this video
https://www.youtube.com/watch?v=GVB7JFH_dMo
In it I show you how to move it with the xbox controller but you can easily substitute a key held action for the same results.
Paul
