I have a project set up with the basic template. If I create a VR project can I import the first project into the new project or bring in the levels from the original project
Hi donied,
I don't believe that there is an import button, however, all you need to do is copy and paste the content folder from your old project to your new project and merge it with your current content folder.
If you had any custom Lua scripts in the script folder than you will need to bring those over too, however make sure you don't overwrite the VR scripts with the ones from your other project!
Hope this helps!
Cheers,
Kaine
