Hi everyone!
I'm attemping to make a unit move in the direction that I rotate it, however I'm very new to programming in 3D.. everything that I've done in the past has always been 2D.
Currently, I have a function that lets me set the yaw, pitch and roll of the object:
function PlayerMovement.set_yaw_pitch_roll(unit, index, yaw, pitch, roll) local yaw_rotation = Quaternion(Vector3.up(), math.rad(yaw)) local pitch_rotation = Quaternion(Vector3.right(), math.rad(pitch)) local roll_rotation = Quaternion(Vector3.forward(), math.rad(roll)) local new_rotation = Quaternion.multiply(Quaternion.multiply(yaw_rotation, pitch_rotation), roll_rotation) Unit.set_local_rotation(unit, index, new_rotation) end
This appears to work fine, I can set any angle and the object will be correctly positioned. Now, when I go to move him, if I were to calculate x and y velocities for a 2D game I would have done it like this:
// pseudo code velX = speed*sin(angle) velY = speed*cos(angle)
Now, my current implementation of this in the Lua for 3D is this:
function PlayerMovement.calculate_transform(unit, index, dt) local curr_velocity = PlayerMovement.velocity:unbox() local frame_velocity = curr_velocity local curr_pos = Unit.local_position(unit, index) Vector3.set_x(frame_velocity, -PlayerMovement.speed * math.sin(math.rad(PlayerMovement.yaw)) * dt * (1-PlayerMovement.pitch/90)) Vector3.set_y(frame_velocity, PlayerMovement.speed * math.cos(math.rad(PlayerMovement.yaw)) * dt * (1-PlayerMovement.pitch/90)) Vector3.set_z(frame_velocity, PlayerMovement.speed * math.sin(math.rad(PlayerMovement.pitch)) * dt) PlayerMovement.velocity:store(frame_velocity) Unit.set_local_position(unit, index, curr_pos+frame_velocity) end
I know the naming conventions are dodgy but I'm only testing!! So this works, until the object pitches past 90 degrees, obviously, as I have my (1-PlayerMovement.pitch/90) line which I THINK eliminates the correct ratio of forward movement compared to vertical, but only works (well.. it looks right anyway haha) for a quarter of the range of motion.
How could I improve this? What should I do to correct for the diminishing amount of forward movement that would result from moving vertically at the same time? I believe my solution is on the right track but only works for a quarter of the motion and I feel like a more elegant solution than a bunch of if statements is waiting out there. And lastly, any suggestions at all for flight in space? (links or books are fine, in any programming language)
Cheers,
Kaine
Update: I've started experimenting with this http://mathworld.wolfram.com/SphericalCoordinates.html which I think looks promising
Sorry for the triple post (too late to edit), just thought I'd post my progress. This is my current transform function to calculate transform using a spherical coordinate system:
function PlayerMovement.transform(unit, index, dt) local curr_pos = Unit.local_position(unit, index)
local speed = PlayerMovement.speed
local x = speed*math.cos(math.rad(PlayerMovement.yaw)) * math.sin(math.rad(PlayerMovement.pitch)) local y = speed*math.sin(math.rad(PlayerMovement.yaw)) * math.sin(math.rad(PlayerMovement.pitch)) local z = speed*math.cos(math.rad(PlayerMovement.pitch)) local frame_velocity = Vector3(x,y,z)*dt Unit.set_local_position(unit,index, curr_pos+frame_velocity) end
Where:
PlayerMovement.speed = radius of the 'sphere' (imaginary sphere!)
PlayerMovement.yaw = azimuthal angle
PlayerMovement.pitch = zenith/polar angle
The issue I'm having is that as the zenith angle is measured from the up-axis (z), a zenith/pitch of 0 degrees is directly upwards and a pitch of 90 is flat. How can I convert my pitch number, to translate to the respective zenith angle? For example, a pitch of 30 degrees should equal a zenith of 60 degrees. As pitch is measured from the xy plane upwards, and zenith is from the z axis downwards..
Besides that I think is much better than my original function, I'm starting to get my head into the space of 3D.
Cheers,
Kaine
Edit: I think I fixed my zenith angle issue, I just simply do (90-pitch) for the angle accepted by my spherical coord system, which makes the angles for pitch behave how I think of it in my head heh.
Any suggestions or advice would be great though!
Hey Dan!
That's awesome! I really appreciate it. Look forward to hearing back from you.
Cheers,
Kaine
