Hi everyone!
I've been exploring how I can implement a function that can return the unit the mouse clicks on.. I've been looking at the functions in the Lua API, so far the ones that have caught my attention have been Camera.world_to_screen() and Camera.screen_to_world(). Also potentially using some form of raycast from the camera, though I can think of a few issues with that. Any ideas or examples on how to accomplish this?
Cheers,
Kaine
Solved by _robbs_. Go to Solution.
In the project.lua, you can do something like below to get the mouse click:
function Project.update(dt) if(stingray.Mouse.pressed(stingray.Mouse.button_id("left"))) then print "mouse left pressed" end if(stingray.Mouse.released(stingray.Mouse.button_id("left"))) then print "mouse left released" end end
After that you'd need to do a cast out and return whatever object you have hit. You could also do something similar with scaleform and listeners.
You can also get the mouse focus in window as below:
-- Used to capture the mouse focus so you can interact with your UI using the mouse stingray.Window.set_mouse_focus(true) stingray.Window.set_clip_cursor(true) stingray.Window.set_show_cursor(true)
Does this help you out at all?
Hey Dan, thanks for the response.
I'm not sure how I would cast out to check. Obviously I'd use a ray tracer but I'm not sure how to determine where to cast the ray.. could I have a more specific example on how to accomplish it?
Thanks!
Kaine
The ray would just be perpendicular to the Camera wouldn't it, now that I actually think about it.. is this correct?
Thanks Dan!
When I said perpendicular I meant parallel as well. Oops. It's 4:50am here, so I'm going to use that as my excuse.
I believe I'm getting closer to having it working, however it'd be awesome to see how the pros do it, as I want to accomplish it in the most efficient way possible.
Cheers,
Kaine
Could you also see if you can find out how to get the vector position of the mouse? i.e (x,y,0)
There isn't a lot of info on the Mouse in docs yet.
Thanks again!!
Kaine
Same question with Kaine, how to get mouse position when mouse pressed/released?
Deviros
Hey Deviros,
This should do the trick:
stingray.Mouse.axis(stingray.Mouse.axis_id("cursor"), stingray.Mouse.RAW, 3).x, stingray.Mouse.axis(stingray.Mouse.axis_id("cursor"), stingray.Mouse.RAW, 3).y)
Cheers,
Kaine
Hi Diviros,
You can return the location of the cursor by using the following:
Thank Dan and Kaine,
Can you give me any mouse button, example : "left", "right", "middle", "cursor" ... blah blah
Deviros
Sorry,
I have a question about Screen_to_world function, this line in player.lua:
local mouse = stingray.Mouse.axis(stingray.Mouse.axis_id("cursor"), stingray.Mouse.RAW, 3) local v3 = stingray.Camera.screen_to_world(self.player_camera, mouse, 1,stingray.Window)
I get error
bad argument #1 to 'screen_to_world' (userdata expected, got table)
So, what is camera parameter in screen_to_world() function?
Thanks!
Deviros
Hi!
To check if a Mouse button is being pressed (this also applies to the Keyboard, you just replace the Mouse namespace with the Keyboard namespace) you can do it like this:
local leftMousePressed = Mouse.button(Mouse.button_id("left"))
This will return 1 while the left mouse button is pressed, and 0 when it's not. Keep in mind that for that line to work you have to cache of the namespace (normally at the top of your Lua file) like this:
local Mouse = stingray.Mouse
This is just so you don't have to put stingray.Mouse everytime, and it also has some slight performance gains I believe, though I could be wrong.
Here is a list of all available mouse button IDs (I haven't tested these):
extra__1 extra__1__double extra__2 extra__2__double left left__double middle middle__double right right__double wheel__down wheel__left wheel__right wheel__up
The Mouse inherits all the functions under the InputController and by extension the BaseInputController so I recommend reading the documentation on those to see exactly what you can do.
BaseInputController Documentation
For your second question:
If you check the documentation for the screen_to_world() (screen_to_world() Documentation) you'll see that is takes a stingray.Camera object as the parameter. The error you recieved is there for the reason it states; player_camera is only a table which is used to store the camera. In the player.lua script under the init() function you'll see it creates the variable:
self.player_camera = {}
the {} defines a blank table. This variable player_camera is used to store the unit which in turn is storing the stingray.Camera object. If you're going through these templates, or using the Appkit then the easiest way to get the actual Camera instance is by using the built in functionality of the camera_wrapper.lua script. An example of putting it all together would look something like:
local player_camera = self.player_camera local camera_wrapper = CameraWrapper.manager:get(player_camera) local camera = camera_wrapper:get_camera()
local mouseXPos = Mouse.axis(Mouse.axis_id("cursor"), Mouse.RAW, 3).x
local mouseYPos = Mouse.axis(Mouse.axis_id("cursor"), Mouse.RAW, 3).y
local depth = 1
local mouseWorldCoords = Camera.screen_to_world(camera, Vector3(mouseXPos, mouseYPos, 0), depth)
As you can see, I've left out the Window parameter from the screen_to_world() function as it is an optional parameter. If it is left out then it uses the largest open application window, so if you only have one window in your application, you don't need to worry about it.
I'd recommened you look through the code from the different Appkit files so you can better understand how it all works together, you can find them under Program Files -> Autodesk -> Stingray -> VersionNumber -> core -> appkit -> lua
Note: Everytime I ommit "stingray." before a namespace i.e on Mouse and Camera, that means I have cached it like was shown above in this post for speed and also readability. I also haven't tested the code so I would just read it as psuedo code. It should work though.
I hope this helps! If you have any issues let me know.
Kaine
I've just been cleaning up the input controller stuff in the docs... Coming next update.
Kaine you have the names right, except you have them with an extra underscore.
Mouse button names
Mouse axis names
Thanks for clarifying! I got the names from the flow editor, and they appear to have double underscores there, not sure if that's a mistake? Thanks though!
Cheers,
Kaine
Hi!
I just wanted to clarify why a post was accepted as a solution? We've had some informative posts but the question I asked hasn't been answered yet.
Cheers,
Kaine
