What is the difference between entities and units
And when should I use which?
mustapha.bismi
The entity system is fairly new within the Stingray ecosystem. Think of them as a loose collection of components. Units, on the other hand, are the common way to describe an actor. You can think of them as a more or less hardcoded template, or a fixed set of components.
At the moment, I would advise to use Units. All the workflows around them are mature, production-proven, and safe in the long run. There is nothing you cannot build using units.
Hope this helps Smiley Happy
