Announcements
ShadingEnvironment - how to make a change work
I have been trying to change the ShadingEnvironment
The code I am using as a template is the example included in the source documentation, but I have changed "sun_direction" to "skydome_intensity" and changed the set_vector3 to set_scalar.
function render()
     stingray.ShadingEnvironment.blend(self.shading_environment, {"default", 1.0})
     stingray.ShadingEnvironment.set_scalar(self.shading_environment, "skydome_intensity", 0.2)
     stingray.ShadingEnvironment.apply(self.shading_environment)
     stingray.Application.render_world(self.world, self.camera, self.viewport, self.shading_environment)
end
Whatever value I change "skydome_intensity" to has no effect to the look of the scene render. It just ignores the value changes.
Any ideas on where I am going wrong?
Brian
lumonix
the lua commands you are using only work on 'old' shading env objects.
Does your level have a 'new' shading env entity?
(one that has components etc?)
If so, then these lua commands don't work on it.
(which imo is kinda of a bug on our end, but that is still being debated)
I'm going to dump a bunch of lua code here to show you how to set the properties for the 'new' shading env entity.
This is pretty sucky and hopefully we will provide a nicer interface for this in the future (or just make the old lua calls work with the new entity)
-- Cached Engine Modules
local Application = stingray.Application
local Keyboard = stingray.Keyboard
local Vector3 = stingray.Vector3
local Quaternion = stingray.Quaternion
local World = stingray.World
local Unit = stingray.Unit
local Window = stingray.Window
local Level = stingray.Level
local EntityManager = stingray.EntityManager
Game = Game or {}
local Game = Game
local shading_env_entity = nil
local exposure_component = nil
function gather_shading_env_params()
	-- this tries to find shading environment variables from the shading env entity
	-- in the future, there may be better API to handle this, but for now we loop all entities.
	local data_component_manager = EntityManager.data_component(Game.world)
	local all_entity_handles = World.entities(Game.world)
	for _, entity_handle in ipairs(all_entity_handles) do
	    local all_data_component_handles = {data_component_manager:instances(entity_handle)} -- Returns values on stack, so wrap in {} to get array.
	    for _, data_component_handle in ipairs(all_data_component_handles) do
	        -- Missing properties return nil, so this is "safe".
	        local shading_environment_mapping_resource_name = data_component_manager:get_property(entity_handle, data_component_handle, {"shading_environment_mapping"})
	        if shading_environment_mapping_resource_name == "core/stingray_renderer/shading_environment_components/exposure" then
	        	if (shading_env_entity == nil) then
	        		shading_env_entity = entity_handle
	        	end
	        	exposure_component = data_component_handle;
	        end
	    end
	end
end
function update_shading_env_entity()
	-- Arrays are immutable - must replace whole array, not a component.
	-- Thus, colors, vectors and ranges are set using whole arrays.
	-- Refer to "core/stingray_renderer/shading_environment_components/fog.component" for available properties.
	--local fog_rgb_linear = {1.0, 0.5, 0.0}
	--local fog_alpha = 1.0
	--local fog_depth_range = {20, 150}
	--data_component_manager:set_property(entity_handle, data_component_handle, {"fog_color", "rgb"}, fog_rgb_linear)
	--data_component_manager:set_property(entity_handle, data_component_handle, {"fog_color", "alpha"}, fog_alpha)
	--data_component_manager:set_property(entity_handle, data_component_handle, {"fog_depth_range"}, fog_depth_range)
	if (shading_env_entity ~= nil) then
		if (exposure_component ~= nil) then
			local exposure_val = 0.2
			data_component_manager:set_property(shading_env_entity, exposure_component, {"exposure"}, exposure_val)
		end
	end
end
function init()
	if LEVEL_EDITOR_TEST and not LEVEL_EDITOR_TEST_READY then
		print("Waiting for test level initialization...")
		return
	end
	Game.world = Application.new_world()
	Game.viewport = Application.create_viewport(Game.world, "default")
	local level = World.load_level(Game.world, "content/levels/empty")
	Level.spawn_background(level)
	Level.trigger_level_loaded(level)
	stingray.Window.set_clip_cursor(true)
	stingray.Window.set_mouse_focus(true)
	stingray.Window.set_show_cursor(true)
	-- even though we have a entitiy shading env in our levels, we still need the 'old' shading environment to pass to render_world in render()
	-- values set in the shading env entity will automatically override the values in the old shading env.
	-- so to get values to change in your level, you need to update them in the entity
	if Level.has_data(level, "shading_environment") then
		print("level has shading env")
		World.set_shading_environment(Game.world, Game.shading_environment, Level.get_data(level, "shading_environment"))
	else
		Game.shading_environment = World.create_shading_environment(Game.world, "core/stingray_renderer/environments/midday/midday")
	end
	Game.camera_unit = World.spawn_unit(Game.world, "core/units/camera")
	--Game.model_unit = stingray.World.unit_by_name(Game.world, "some_model");
	--model_position = stingray.Unit.local_position(Game.model_unit, 1);
end
function update(dt)
	if LEVEL_EDITOR_TEST and not LEVEL_EDITOR_TEST_READY then return end
	Game.world:update(dt)
end
function render()
	local camera = Unit.camera(Game.camera_unit, "camera")
	Application.render_world(Game.world, camera, Game.viewport, Game.shading_environment)
end
Hi Lumonix,
Thanks for the reply and explanation of why the code didn't work.
I will do as you suggest and use your code as a template to move forward.
You help is appreciated.
Cheers
Brian
Is this code still relevant in the latest version (1.1.247) ?
I'm trying to do something similar to change the skydome intensity from a script but can't get it to work. Some variables, like Game, seem to not exist anymore so I don't know where to get the world from.
Hi Elifer,
Yes the code still works.
I have created my own Shading Environment class called ShadingEnvParam.lua which is attached to this post. Rename it from ShadingEnvParam.lua.txt to ShadingEnvParam.lua, we are not allowed to upload lua attachments! Hopefully this code will help you.
To use the class just add the following lines of code into your project at the relevant places. You mention the variable Game not existing. Game is just a table variable used to hold many of the initial objects created at init(). So, add the following 5 lines of code into your project.
-- to include the class into your codebase
require 'ShadingEnvParam'
-- create a variable we will use to change the sky dome
local shadingVar = nil
-- in the init() function you need to initialize shadingVar
-- Game.world is a variable initialized before (usually in init) with Game.world = Application.new_world()
shadingVar = ShadingEnvParam.Init(Game.world)
-- in the update() function add these 2 lines before  Game.world:update(dt)
 shadingVar:ChangeComponent("core/stingray_renderer/shading_environment_components/global_lighting")
 shadingVar:Update({{"skydome_intensity"}, 0.1})
And that should do it. I added those exact 5 lines of code into the project available here https://forums.autodesk.com/t5/stingray/stingray-l​ua-memento-project-video/td-p/5803936 and it worked fine. I got a nice dark sky.
Hope this helps you.
Brian
dan.matlack
@Anonymous Please let us know if the above helps you out or if you still need some assistance. 🙂
______________________________________
Dan Matlack
Senior Content Manager || Games Solutions
Autodesk, Inc.
Sorry for the delay in answering. I actually managed to get the original code working by removing references to Game, and getting the world from SimpleProject instead.
I will try the code you posted anyway, see if it's a cleaner solution.
Thanks!
