RenderBufferApi::update_buffer completion?
I'm using the Plugin API's RenderBufferApi to dynamically update a texture. So for this I'm using the update_buffer function.
It seems to me that this function completes asynchronously.
Which leads me to my question, how do I know when this method call has completed?
How do I know when it's safe to access the buffer again on my side? Specifically,  delete it or update it?
Peeking into the engine source  it looks like I can use the RenderInterfaceApi::create_fence and wait_for_fence for this. Is that correct?
__ben__
As best I can tell the update_buffer() function completes synchronously. It should be called during the update portion of the game loop. As long as the contents of the buffer have settled by the end of the update segment, rendering will proceed normally.
Two code examples that demonstrate use of update_buffer() can be found here:
https://help.autodesk.com/view/Stingray/ENU/?guid=__lua_ref_exa_ex__snippets_proc__meshes_html
https://github.com/AutodeskGames/stingray-plugin/wiki/How-to-create-a-cool-plugin
Hi, that really doesn't sound true. In a threaded engine mode, it seems that the the request is really put into a message buffer and then performed on another thread. (see RenderInterface::dispatch, RenderInterface::post_message)
Also it seems that the RenderInterfaceApi::create_fence and RenderInterfaceApi::wait_for_fence really are the things that I want.
Thanks.
