Levels not loading editor in v1.6
Message 1 of 10
Hi All,
Is anyone having the same problem after upgrading to v1.6?
Right now, my level viewport is stuck in constant loading and it's not showing the level and objects. However, when i build or F8 run the project, it works and renders properly.
Please do help!!!
Update: This happens even when i download and open the nav_flow online example provided by Autodesk.
Replies (9)
Message 2 of 10
andrew.grant
Do you get any errors in the log console? If so please post the full error log here.
Also, could you provide system details? (windows version, graphics card, driver version, etc)
-Thanks!
Andrew
Message 3 of 10
paul.kind
You can also try window > reset layout
This often will fix this type of issue.
Areas of Expertise - MayaLT : Mudbox : 3DS Max : Inventor : Game Dev
Follow me on Twitter : @paulkind3d
Please remember to give kudos freely and mark acceptable answers as solved!
PLEASE do not send me private messages unless asked to do so. If you have a question, start a thread, and ask me on the public forums where answering your question may help others.
Did you know there was a YouTube learning channel for Autodesk Games? New videos are posted regularly with all sorts of content relative to Stingray, Maya/MayaLT, 3DS Max, and other game related tools. Get your game on @ https://www.youtube.com/user/autodeskgameshowtos
Message 4 of 10
Hi Paul. Thanks for the help, but reset layout doesnt solve the problem unfortunately 😞
Message 5 of 10
Hi Andrew,
Nopes, I'm not getting any errors for the console.
Here are my system details with GFX card GeForce GTX 980 v369.09
Message 6 of 10
andrew.grant
Two things to try:
Update your nvidia drivers - yours is relatively old.
Second, if that doesn't work, is to clear you Stingray appdata:
In your user folder under:
<user>/AppData/Local/Autodesk/Stingray...
Backup the existing Stingray folder, then delete it or rename it and restart Stingray. You will need to re-add your projects to the project manager.
Let us know if either of those work for you. If it is the latter (clearing appdata) then it would help if you could share the contents of your appdata with us.
Thanks!
-Andrew
Message 7 of 10
Thanks Andrew for helping out!
Clearing the AppData worked out for me! Thanks so much!
What are the information/files that you need?
Do let me know 🙂
Message 8 of 10
andrew.grant
If you could share the problematic files from here:
\AppData\Local\Autodesk\Stingray\Settings
This would help us find the exact issue.
Thanks!
Message 9 of 10
Hey Andrew,
Could you pass me your email? I'm concerned about the sensitive information that might be inside so I can't really share on the forums. Hope you understand 🙂
Message 10 of 10
andrew.grant
You can click on my name and send me a private message if you like.
-Andrew
