Stingray Forum (Read Only)
Welcome to Autodesk’s Stingray Forums. Share your knowledge, ask questions, and explore popular Stingray topics.
iOS Package Server crashes when setting entitlements
7 REPLIES 7
Message 1 of 8
tnydwrds
2358 Views, 7 Replies
I'm having issues with the iOS Package Server crashing 100% of the time when it attempts to set entitlements. I'm using a development certificate and provisioning profile that can successfully build other apps to my devices in Xcode without issue. My environment details are:
Stingray Version: 1.8.1267
macOS Version: 10.12.5 (Sierra)
Xcode Version: 8.3.3
The specific crash seems to be related to parsing a property list. And it looks like this has been a problem for other non-Autodesk packaging/signing tools as well:
https://github.com/maciekish/iReSign/issues/99
https://github.com/maciekish/iReSign/pull/96
Here is a snippet of the crash report I am seeing:
Process:               Autodesk Stingray iOS Package Server [15301]
Path:                  /Applications/Autodesk Stingray iOS Package Server.app/Contents/MacOS/Autodesk Stingray iOS Package Server
Identifier:            com.autodesk.Autodesk-Stingray-iOS-Package-Server
Version:               1.8.1267 (1.8.1267)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Autodesk Stingray iOS Package Server [15301]
Date/Time:             2017-06-23 23:17:56.446 -0700
OS Version:            Mac OS X 10.12.5 (16F73)
Report Version:        12
Crashed Thread:        7
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Application Specific Information:
*** Terminating app due to uncaught exception 'NSParseErrorException', reason: 'Error Domain=NSCocoaErrorDomain Code=3840 "Unexpected character s at line 1" UserInfo={NSDebugDescription=Unexpected character s at line 1, kCFPropertyListOldStyleParsingError=Error Domain=NSCocoaErrorDomain Code=3840 "Unexpected ';' or '=' after key at line 1" UserInfo={NSDebugDescription=Unexpected ';' or '=' after key at line 1}}'
terminating with uncaught exception of type NSException
abort() called
Application Specific Backtrace 1:
0   CoreFoundation                      0x00007fffcee6c57b __exceptionPreprocess + 171
1   libobjc.A.dylib                     0x00007fffe42301da objc_exception_throw + 48
2   CoreFoundation                      0x00007fffceee9c55 +[NSException raise:format:] + 197
3   Foundation                          0x00007fffd08f8e82 -[NSString(NSExtendedStringPropertyListParsing) propertyList] + 216
4   Autodesk Stingray iOS Package Server 0x0000000103a06528 +[Utilities generateEntitlementsWithProvision:] + 536
5   Autodesk Stingray iOS Package Server 0x0000000103a0549f -[Packager packageIPA:withData:andPackageOptions:andSigningCertificate:andProvision:andEntitlements:andLogDeleagte:] + 3455
6   Autodesk Stingray iOS Package Server 0x0000000103a02441 -[PackageConnection processData] + 1841
7   Foundation                          0x00007fffd0824b3d __NSThread__start__ + 1243
8   libsystem_pthread.dylib             0x000000010453c93b _pthread_body + 180
9   libsystem_pthread.dylib             0x000000010453c887 _pthread_body + 0
10  libsystem_pthread.dylib             0x000000010453c08d thread_start + 13
Thread 7 Crashed: 0 libsystem_kernel.dylib 0x00000001043dcd42 __pthread_kill + 10 1 libsystem_pthread.dylib 0x000000010453f457 pthread_kill + 90 2 libsystem_c.dylib 0x0000000104300420 abort + 129 3 libc++abi.dylib 0x00007fffe36ff84a abort_message + 266 4 libc++abi.dylib 0x00007fffe3724c4f default_terminate_handler() + 267 5 libobjc.A.dylib 0x00007fffe423233e _objc_terminate() + 103 6 libc++abi.dylib 0x00007fffe3721d69 std::__terminate(void (*)()) + 8 7 libc++abi.dylib 0x00007fffe37217de __cxa_throw + 121 8 libobjc.A.dylib 0x00007fffe4230303 objc_exception_throw + 345 9 com.apple.CoreFoundation 0x00007fffceee9c55 +[NSException raise:format:] + 197 10 com.apple.Foundation 0x00007fffd08f8e82 -[NSString(NSExtendedStringPropertyListParsing) propertyList] + 216 11 com.autodesk.Autodesk-Stingray-iOS-Package-Server 0x0000000103a06528 +[Utilities generateEntitlementsWithProvision:] + 536 12 com.autodesk.Autodesk-Stingray-iOS-Package-Server 0x0000000103a0549f -[Packager packageIPA:withData:andPackageOptions:andSigningCertificate:andProvision:andEntitlements:andLogDeleagte:] + 3455 13 com.autodesk.Autodesk-Stingray-iOS-Package-Server 0x0000000103a02441 -[PackageConnection processData] + 1841 14 com.apple.Foundation 0x00007fffd0824b3d __NSThread__start__ + 1243 15 libsystem_pthread.dylib 0x000000010453c93b _pthread_body + 180 16 libsystem_pthread.dylib 0x000000010453c887 _pthread_start + 286 17 libsystem_pthread.dylib 0x000000010453c08d thread_start + 13
In reviewing previous posts with similar problems, it looks like all of them passed this step, but I'm thinking this wasn't an issue with older versions of macOS and/or Xcode?
https://forums.autodesk.com/t5/stingray-forum/bug-stingray-ios-packager-server/td-p/6206053
https://forums.autodesk.com/t5/stingray-forum/failed-to-ios-deploy/m-p/6297105
https://forums.autodesk.com/t5/stingray-forum/build-to-ios-error/m-p/6918178
Has anyone else had luck packaging anything with recent versions of macOS and Xcode? Is there something I'm missing in my setup?
7 REPLIES 7
Message 2 of 8
tnydwrds
in reply to: tnydwrds
 Meh. Maybe that last thread could have been a more recent version. There's no guarantee though as it doesn't mention versions anywhere. Smiley Sad
Message 3 of 8
tnydwrds
Smiley Indifferent
I checked the supported platforms documentation a little more thoroughly and sadly came across this:
iOS Version Compatibility
The Stingray engine only supports iOS devices running iOS 9 .
Requirements for Running the Stingray iOS Packaging Server
In order to package games from Windows you need to run the Stingray iOS package server on a Mac device with Mac OS X 10.10 (Yosemite) and Xcode 7 or 8 . Please download these from https://developer.apple.com/downloads. We recommend you disable auto update on your Apple development machine.
I saw older devices listed and iOS 9, assumed the documentation just hadn't been updated and inferred "or later". Is this accurate and the official answer to my problem is I have an unsupported development environment? Which would be sad, but meh... Or am I missing something silly in my setup?
@__ben__ I saw you actively responding to older threads earlier today. I was hoping you would make it to mine. Is this something you can help with?
Message 4 of 8
I'm experiencing what I think the same crash, did you find a solution? Grateful for any help, been trying to fix this all day 😞
log:
Process: Autodesk Stingray iOS Package Server [2059]
Responsible: Autodesk Stingray iOS Package Server [2059]
User ID: 501
Date/Time: 2017-09-13 18:43:52.234 +0200
OS Version: Mac OS X 10.12.6 (16G29)
Report Version: 12
Anonymous UUID: ***
Time Awake Since Boot: 2000 seconds
System Integrity Protection: enabled
Crashed Thread: 7
abort() called
0 CoreFoundation 0x00007fffba38c2cb __exceptionPreprocess + 171
1 libobjc.A.dylib 0x00007fffcf1a448d objc_exception_throw + 48
2 CoreFoundation 0x00007fffba40ac3d +[NSException raise:format:] + 205
3 Foundation 0x00007fffbbdf9de2 -[NSString(NSExtendedStringPropertyListParsing) propertyList] + 216
4 Autodesk Stingray iOS Package Server 0x0000000100550528 +[Utilities generateEntitlementsWithProvision:] + 536
5 Autodesk Stingray iOS Package Server 0x000000010054f49f -[Packager packageIPA:withData:andPackageOptions:andSigningCertificate:andProvision:andEntitlements:andLogDeleagte:] + 3455
6 Autodesk Stingray iOS Package Server 0x000000010054c441 -[PackageConnection processData] + 1841
7 Foundation 0x00007fffbbd258ad __NSThread__start__ + 1243
8 libsystem_pthread.dylib 0x00007fffcfca393b _pthread_body + 180
9 libsystem_pthread.dylib 0x00007fffcfca3887 _pthread_body + 0
10 libsystem_pthread.dylib 0x00007fffcfca308d thread_start + 13
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fffcfbb134a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fffcfbb0797 mach_msg + 55
2 com.apple.CoreFoundation 0x00007fffba303434 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fffba3028c1 __CFRunLoopRun + 1361
4 com.apple.CoreFoundation 0x00007fffba302114 CFRunLoopRunSpecific + 420
5 com.apple.HIToolbox 0x00007fffb9862ebc RunCurrentEventLoopInMode + 240
6 com.apple.HIToolbox 0x00007fffb9862cf1 ReceiveNextEventCommon + 432
7 com.apple.HIToolbox 0x00007fffb9862b26 _BlockUntilNextEventMatchingListInModeWithFilter + 71
8 com.apple.AppKit 0x00007fffb7dfba54 _DPSNextEvent + 1120
9 com.apple.AppKit 0x00007fffb85777ee -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796
10 com.apple.AppKit 0x00007fffb7df03db -[NSApplication run] + 926
11 com.apple.AppKit 0x00007fffb7dbae0e NSApplicationMain + 1237
12 libdyld.dylib 0x00007fffcfa8a235 start + 1
Thread 1:
0 libsystem_kernel.dylib 0x00007fffcfbb944e __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fffcfca3621 _pthread_wqthread + 1426
2 libsystem_pthread.dylib 0x00007fffcfca307d start_wqthread + 13
Thread 2:: com.apple.NSEventThread
5 com.apple.AppKit 0x00007fffb7f48f02 _NSEventThread + 205
6 libsystem_pthread.dylib 0x00007fffcfca393b _pthread_body + 180
7 libsystem_pthread.dylib 0x00007fffcfca3887 _pthread_start + 286
8 libsystem_pthread.dylib 0x00007fffcfca308d thread_start + 13
Thread 3:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fffcfbb8eb6 __select + 10
1 com.apple.CoreFoundation 0x00007fffba33e66a __CFSocketManager + 682
2 libsystem_pthread.dylib 0x00007fffcfca393b _pthread_body + 180
3 libsystem_pthread.dylib 0x00007fffcfca3887 _pthread_start + 286
4 libsystem_pthread.dylib 0x00007fffcfca308d thread_start + 13
Thread 4:
1 libsystem_pthread.dylib 0x00007fffcfca348e _pthread_wqthread + 1023
Thread 5:: com.apple.NSURLConnectionLoader
5 com.apple.CFNetwork 0x00007fffb943f734 +[NSURLConnection(Loader) _resourceLoadLoop:] + 313
6 com.apple.Foundation 0x00007fffbbd258ad __NSThread__start__ + 1243
7 libsystem_pthread.dylib 0x00007fffcfca393b _pthread_body + 180
8 libsystem_pthread.dylib 0x00007fffcfca3887 _pthread_start + 286
9 libsystem_pthread.dylib 0x00007fffcfca308d thread_start + 13
Thread 6:
Thread 7 Crashed:
0 libsystem_kernel.dylib 0x00007fffcfbb8d42 __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fffcfca6457 pthread_kill + 90
2 libsystem_c.dylib 0x00007fffcfb1e420 abort + 129
3 libc++abi.dylib 0x00007fffce67194a abort_message + 266
4 libc++abi.dylib 0x00007fffce696c2f default_terminate_handler() + 267
5 libobjc.A.dylib 0x00007fffcf1a66fe _objc_terminate() + 103
6 libc++abi.dylib 0x00007fffce693d49 std::__terminate(void (*)()) + 8
7 libc++abi.dylib 0x00007fffce6937be __cxa_throw + 121
8 libobjc.A.dylib 0x00007fffcf1a45b6 objc_exception_throw + 345
9 com.apple.CoreFoundation 0x00007fffba40ac3d +[NSException raise:format:] + 205
10 com.apple.Foundation 0x00007fffbbdf9de2 -[NSString(NSExtendedStringPropertyListParsing) propertyList] + 216
11 com.autodesk.Autodesk-Stingray-iOS-Package-Server 0x0000000100550528 +[Utilities generateEntitlementsWithProvision:] + 536
12 com.autodesk.Autodesk-Stingray-iOS-Package-Server 0x000000010054f49f -[Packager packageIPA:withData:andPackageOptions:andSigningCertificate:andProvision:andEntitlements:andLogDeleagte:] + 3455
13 com.autodesk.Autodesk-Stingray-iOS-Package-Server 0x000000010054c441 -[PackageConnection processData] + 1841
14 com.apple.Foundation 0x00007fffbbd258ad __NSThread__start__ + 1243
15 libsystem_pthread.dylib 0x00007fffcfca393b _pthread_body + 180
16 libsystem_pthread.dylib 0x00007fffcfca3887 _pthread_start + 286
17 libsystem_pthread.dylib 0x00007fffcfca308d thread_start + 13
Thread 8:
Thread 9:: com.apple.appkit-heartbeat
0 libsystem_kernel.dylib 0x00007fffcfbb8f46 __semwait_signal + 10
1 libsystem_c.dylib 0x00007fffcfb3fb72 nanosleep + 199
2 libsystem_c.dylib 0x00007fffcfb3fa66 usleep + 54
3 com.apple.AppKit 0x00007fffb80c5af6 -[NSUIHeartBeat _heartBeatThread:] + 2696
Thread 10:
0 libsystem_kernel.dylib 0x00007fffcfbb8c22 __psynch_mutexwait + 10
1 libsystem_pthread.dylib 0x00007fffcfca3dfa _pthread_mutex_lock_wait + 100
2 com.apple.Foundation 0x00007fffbbcfadc2 -[NSLock lock] + 145
3 com.apple.AppKit 0x00007fffb80c5117 -[NSUIHeartBeat _heartBeatThread:] + 169
Thread 7 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000006 rcx: 0x0000700006a33108 rdx: 0x0000000000000000
rdi: 0x00000000000053ef rsi: 0x0000000000000006 rbp: 0x0000700006a33130 rsp: 0x0000700006a33108
r8: 0x00007fffcfb47650 r9: 0x00007fffcfb09a50 r10: 0x0000000008000000 r11: 0x0000000000000206
r12: 0x0000700006a33290 r13: 0x0000000000000030 r14: 0x0000700006a35000 r15: 0x0000000000000008
rip: 0x00007fffcfbb8d42 rfl: 0x0000000000000206 cr2: 0x00007fffd8989128
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Binary Images:
0x100549000 - 0x100557ff7 +com.autodesk.Autodesk-Stingray-iOS-Package-Server (1.8.1267 - 1.8.1267) <6D4AD63D-25EE-387E-915A-362DC49D46C8> /Applications/Autodesk Stingray iOS Package Server.app/Contents/MacOS/Autodesk Stingray iOS Package Server
0x102023000 - 0x102060dc7 dyld (433.5) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld
0x105453000 - 0x1055f9fff GLEngine (14.0.16) <08F2E804-13D2-3E80-9322-1A23A84A55F3> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x105638000 - 0x105b93ff7 com.apple.driver.AppleIntelHD5000GraphicsGLDriver (10.25.17 - 10.2.5) <37814D97-7FB0-3378-BF1E-375CE00043ED> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsGLDriver
0x105daf000 - 0x105dd9fff GLRendererFloat (14.0.16) <6B57F70A-EFAC-3DB2-B9BA-E55D05D44DB5> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x105e01000 - 0x105e79ff7 com.apple.driver.AppleIntelHD5000GraphicsMTLDriver (10.25.17 - 10.2.5) <256C1732-C04F-3952-9630-9AE95BDCB245> /System/Library/Extensions/AppleIntelHD5000GraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsMTLDriver
0x106777000 - 0x106791ff7 com.apple.security.csparser (3.0 - 57740.60.18) <119893A8-D878-3AF2-BA3C-F70D5C6E6950> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
0x10c79c000 - 0x10c7bcfff com.apple.CoreNLP (1.0 - 78.2) <B686BDA2-A162-3D70-9257-FEB0592DBD7E> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fffb4f2c000 - 0x7fffb5271ff7 com.apple.RawCamera.bundle (7.04 - 914) <86A67D11-9791-3CE6-9FF5-3387C0AB925B> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fffb587e000 - 0x7fffb60cbfff com.apple.GeForceGLDriver (10.17.5 - 10.1.7) <CB32FE96-F197-3605-929B-DC4D7E8BBCA7> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
0x7fffb60cc000 - 0x7fffb6991ff3 libclh.dylib (4.0.3 - 4.0.3) <2CA40E20-9E48-3A2E-A0A4-2AAAF150F723> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
0x7fffb6992000 - 0x7fffb6aa2ff7 com.apple.GeForceMTLDriver (10.17.5 - 10.1.7) <CE0C6DDC-FCB7-3137-A8C3-75DCEF5DEA61> /System/Library/Extensions/GeForceMTLDriver.bundle/Contents/MacOS/GeForceMTLDriver
0x7fffb6aa8000 - 0x7fffb6c69fff com.apple.avfoundation (2.0 - 1187.36) <2F390EAD-07BB-3788-9E73-13104C2E04CD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fffb6c6a000 - 0x7fffb6d0cff7 com.apple.audio.AVFAudio (1.0 - ???) <7997D588-B542-3EBB-B822-D719C1114BB4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fffb6dd7000 - 0x7fffb6dd7fff com.apple.Accelerate (1.11 - Accelerate 1.11) <916E360F-323C-3AE1-AB3D-D1F3B284AEE9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fffb6dd8000 - 0x7fffb6defffb libCGInterfaces.dylib (331.5) <17109679-A284-3C72-AA60-DBA815D3062B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fffb6df0000 - 0x7fffb7309feb com.apple.vImage (8.1 - ???) <B58A7937-BEE2-38FE-87F4-5D5F40D31DC9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fffb730a000 - 0x7fffb747bff3 libBLAS.dylib (1185.50.4) <4087FFE0-627E-3623-96B4-F0A9A1991E09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fffb747c000 - 0x7fffb7490ffb libBNNS.dylib (15) <254698C7-7D36-3FFF-864E-ADEEEE543076> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fffb7491000 - 0x7fffb7887fef libLAPACK.dylib (1185.50.4) <C35FFB2F-A0E6-3903-8A3C-113A74BCBCA2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fffb7888000 - 0x7fffb789efff libLinearAlgebra.dylib (1185.50.4) <345CAACF-7263-36EF-B69B-793EA8B390AF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fffb789f000 - 0x7fffb78a5fff libQuadrature.dylib (3) <EF56C8E6-DE22-3C69-B543-A8648F335FDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fffb78a6000 - 0x7fffb78baff7 libSparseBLAS.dylib (1185.50.4) <67BA432E-FB59-3C78-A8BE-ED4274CBC359> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fffb78bb000 - 0x7fffb7a42fe7 libvDSP.dylib (600.60.1) <4155F45B-41CD-3782-AE8F-7AE740FD83C3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fffb7a43000 - 0x7fffb7af5fff libvMisc.dylib (600.60.1) <E18365D7-DCC4-3304-A8D1-395E656D7B99> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fffb7af6000 - 0x7fffb7af6fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <7C5733E7-0568-3E7D-AF61-160F19FED544> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fffb7af7000 - 0x7fffb7b34ffb com.apple.Accounts (113 - 113) <8550BD08-7D05-3AC4-A0CC-B67ECB2DE950> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fffb7b35000 - 0x7fffb7db4ff7 com.apple.AddressBook.framework (10.0 - 1756.20) <E512B69B-8DBE-3085-95BE-750B8EFC97FD> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x7fffb7db5000 - 0x7fffb8b8eff3 com.apple.AppKit (6.9 - 1504.83.101) <AE51ACB3-D501-3F91-B369-3D3711F24D0A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fffb8ba0000 - 0x7fffb8ba0fff com.apple.ApplicationServices (48 - 48) <DA687F9A-7B2D-342B-8796-16E45344F853> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fffb8ba1000 - 0x7fffb8c0fff7 com.apple.ApplicationServices.ATS (377 - 422.2) <A31D17BE-F747-39FB-9A84-5F2F8891204C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fffb8ca9000 - 0x7fffb8dd8ff7 libFontParser.dylib (194.12) <73C3946D-EF92-3AC1-89C3-0E75B2A85325> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fffb8dd9000 - 0x7fffb8e23fff libFontRegistry.dylib (196.4) <EA96AE47-3369-3DEA-BB82-98348ADBD85B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fffb8e80000 - 0x7fffb8eb3fff libTrueTypeScaler.dylib (194.12) <8944A23A-EE36-3657-9B4F-933231C8FDEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fffb8f20000 - 0x7fffb8fcaff7 com.apple.ColorSync (4.12.0 - 502.2) <ACA4001E-A0E3-33F6-9CD6-EEC2AA15E322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fffb8fcb000 - 0x7fffb901cfff com.apple.HIServices (1.22 - 593) <045870A9-1D92-3FEF-8722-671E99A35E71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fffb901d000 - 0x7fffb902cff3 com.apple.LangAnalysis (1.7.0 - 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fffb902d000 - 0x7fffb907afff com.apple.print.framework.PrintCore (12 - 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fffb907b000 - 0x7fffb90b6fff com.apple.QD (3.12 - 313) <B339C41D-8CDF-3342-8414-F9717DCCADD4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fffb90b7000 - 0x7fffb90c2fff com.apple.speech.synthesis.framework (6.6.2 - 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fffb90c3000 - 0x7fffb92cfff7 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <01518CAB-7DAD-3F09-83F8-B9FE0ABE998F> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fffb92d0000 - 0x7fffb92d0fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <B92868F8-2F15-32C0-A5BE-4ABA546B8BE1> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fffb9439000 - 0x7fffb9813fff com.apple.CFNetwork (811.5.4 - 811.5.4) <46B1227B-F38C-3F8E-B0B5-5D9861ABF36B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fffb982d000 - 0x7fffb982dfff com.apple.Carbon (154 - 157) <69F403C7-F0CB-34E6-89B0-235CF4978C17> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fffb982e000 - 0x7fffb9831fff com.apple.CommonPanels (1.2.6 - 98) <BF04BB22-D54C-309E-9F5C-897D969CAF70> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fffb9832000 - 0x7fffb9b3bfff com.apple.HIToolbox (2.1.1 - 857.8) <5367366E-747E-32CF-8E76-93CD8E7424C7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fffb9b3c000 - 0x7fffb9b3fff7 com.apple.help (1.3.5 - 49) <B1A930E3-5907-3677-BACD-858EF68B172D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fffb9b40000 - 0x7fffb9b45fff com.apple.ImageCapture (9.0 - 9.0) <341252B4-E082-361A-B756-6A330259C741> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fffb9b46000 - 0x7fffb9bddff3 com.apple.ink.framework (10.9 - 219) <1BD40B45-FD33-3177-A935-565EE5FC79D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fffb9bde000 - 0x7fffb9bf8fff com.apple.openscripting (1.7 - 172) <31CFBB35-24BD-3E12-9B6B-1FA842FB605B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fffb9bf9000 - 0x7fffb9bfaff3 com.apple.print.framework.Print (12 - 267) <E2F82F1F-DC27-3EF0-9F75-B354F701450A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fffb9bfb000 - 0x7fffb9bfdff7 com.apple.securityhi (9.0 - 55006) <DBD65629-535D-3669-8218-7F074D61638C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fffb9bfe000 - 0x7fffb9c04ff7 com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <082895DC-3AC7-3DEF-ADCA-5B018C19C9D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fffb9c05000 - 0x7fffb9ce4ffb com.apple.cloudkit.CloudKit (651.14 - 651.14) <9F901E45-23E3-3F45-B66F-1BAB3AFC4462> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fffb9ce5000 - 0x7fffb9ce5fff com.apple.Cocoa (6.11 - 22) <85EDFBE1-75F0-369E-8CA8-C6A639B98FA6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fffb9e2f000 - 0x7fffb9ebcfff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <78767F88-91D4-31CE-AAC6-1F9407F479BB> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fffb9ebd000 - 0x7fffb9ed0fff com.apple.CoreBluetooth (1.0 - 1) <BCB78777-76F0-3CC1-8443-9E61AEF7EF63> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fffb9ed1000 - 0x7fffba1ccfff com.apple.CoreData (120 - 754.2) <4C9CAB2C-60D4-3694-A0A0-5B04B14BD14E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fffba1cd000 - 0x7fffba27aff7 com.apple.CoreDisplay (1.0 - 1) <53D1EAFE-23A4-398D-BF52-E4299E670DB6> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fffba27b000 - 0x7fffba714ff7 com.apple.CoreFoundation (6.9 - 1349.8) <09ED473E-5DE8-307F-B55C-16F6419236D5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fffba715000 - 0x7fffbad97fff com.apple.CoreGraphics (2.0 - 1070.22) <FAB476BB-B5CD-3936-8AFC-41229DBDF0E8> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fffbad98000 - 0x7fffbafdbffb com.apple.CoreImage (12.4.0 - 451.4.9) <BE4303C9-C9D9-361D-AC94-DBE40EB6700E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fffbafdc000 - 0x7fffbb041ff7 com.apple.corelocation (2101.0.63) <C4C6BE27-85E2-34D5-AEDC-EBB5A7CB78D1> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fffbb042000 - 0x7fffbb0f3fff com.apple.CoreMedia (1.0 - 1907.59.1.6) <570690D8-A956-3629-9E46-4F8BDDB8A82C> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fffbb0f4000 - 0x7fffbb13fff7 com.apple.CoreMediaIO (805.0 - 4932) <03F2B863-BF99-36DF-9A14-1DB534A289F3> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fffbb140000 - 0x7fffbb140fff com.apple.CoreServices (775.19 - 775.19) <7255917D-EFBB-3BE2-A8FD-DAD631BC0949> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fffbb141000 - 0x7fffbb192fff com.apple.AE (712.5 - 712.5) <61F2AE2C-E04E-3FDF-9E88-201325136C83> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fffbb193000 - 0x7fffbb46eff7 com.apple.CoreServices.CarbonCore (1159.6 - 1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fffbb46f000 - 0x7fffbb4a2fff com.apple.DictionaryServices (1.2 - 274) <D23866E2-F7C8-3984-A9D4-96552CCDE573> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fffbb4a3000 - 0x7fffbb4abff3 com.apple.CoreServices.FSEvents (1230.50.1 - 1230.50.1) <2AD1B0E5-7214-37C4-8D11-A27C9CAC0F74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fffbb4ac000 - 0x7fffbb618ff7 com.apple.LaunchServices (775.19 - 775.19) <B75A0C49-E376-358C-81EE-6EFB0F605801> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fffbb619000 - 0x7fffbb6c9ffb com.apple.Metadata (10.7.0 - 1075.40) <B2FFCC10-5A9E-396B-B495-3D6C867669EE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fffbb6ca000 - 0x7fffbb729fff com.apple.CoreServices.OSServices (775.19 - 775.19) <4140569A-1848-3765-A52B-BB61C35CF88F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fffbb72a000 - 0x7fffbb79afff com.apple.SearchKit (1.4.0 - 1.4.0) <7A6DDA2B-03F1-3137-BA9E-1CC211973E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fffbb79b000 - 0x7fffbb7e0ff7 com.apple.coreservices.SharedFileList (38 - 38) <DA096678-93AB-3291-BDE2-482F1D544589> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fffbb869000 - 0x7fffbb9b6ffb com.apple.CoreText (352.0 - 544.15) <BF0EE575-BB7E-3BF9-9029-232B4ADC24E4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fffbb9b7000 - 0x7fffbb9ecff3 com.apple.CoreVideo (1.8 - 235.3) <AC11D5FB-C77B-34F5-B942-F698E84C229F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fffbb9ed000 - 0x7fffbba5effb com.apple.framework.CoreWLAN (11.0 - 1200.31) <E47C0568-E37B-3052-9E77-F0F371DCDE7F> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fffbba91000 - 0x7fffbba9cff3 com.apple.DirectoryService.Framework (10.12 - 194) <45BEA292-4550-3082-8CE7-5D6CE7E0052A> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fffbba9d000 - 0x7fffbbb5bff7 com.apple.DiscRecording (9.0.3 - 9030.4.5) <9397E609-CB54-37B2-B28E-D4BC6C34BFAB> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fffbbb5c000 - 0x7fffbbb61fff com.apple.DiskArbitration (2.7 - 2.7) <70F56042-EF04-3BAF-9E04-90F423FB2BCC> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fffbbcf3000 - 0x7fffbc099fff com.apple.Foundation (6.9 - 1349.91) <A37CB4EC-0730-3DD6-9358-60491BF40EF2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fffbc0c5000 - 0x7fffbc0f6ff7 com.apple.GSS (4.0 - 2.0) <6FADED0B-0425-3567-A75A-040C5A4638EB> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fffbc1b6000 - 0x7fffbc259fff com.apple.Bluetooth (5.0.5 - 5.0.5f1) <913B97A6-9E18-3F15-992D-D522AA22EDE9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fffbc25a000 - 0x7fffbc2f0ff7 com.apple.framework.IOKit (2.0.2 - 1324.60.3) <7CE4C98B-107C-3AAA-B49A-F2ACFCBBF526> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fffbc2f1000 - 0x7fffbc2f7ffb com.apple.IOSurface (159.9 - 159.9) <08F1A246-1367-32EC-B3CE-724379409729> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fffbc2f8000 - 0x7fffbc349ff7 com.apple.ImageCaptureCore (7.0 - 7.0) <A640CA2F-8093-34AB-947C-26679ECB8A6D> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fffbc34a000 - 0x7fffbc4aafef com.apple.ImageIO.framework (3.3.0 - 1599.12) <E54ADBF0-6001-3DEB-AEB0-3F857A781E06> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fffbc4ab000 - 0x7fffbc4affff libGIF.dylib (1599.12) <A0836C44-9566-32A3-ACCF-82A5BAF2E521> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fffbc4b0000 - 0x7fffbc5a0ff7 libJP2.dylib (1599.12) <0DB4F152-B36D-365C-97B1-34F1C114982B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fffbc5a1000 - 0x7fffbc5c4ffb libJPEG.dylib (1599.12) <2F66BA16-D569-35AD-A4BB-7A1909F1BF11> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fffbc5c5000 - 0x7fffbc5ecff7 libPng.dylib (1599.12) <A068239E-7DB3-33AD-BEA9-499D8DEF771B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fffbc5ed000 - 0x7fffbc5efff3 libRadiance.dylib (1599.12) <D26D6FC9-1175-38AB-ACAA-0CA073FD3978> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fffbc5f0000 - 0x7fffbc63effb libTIFF.dylib (1599.12) <5D161E6A-D279-37A0-9F5F-A71A4C13BB09> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fffbc79c000 - 0x7fffbd3a6fff com.apple.JavaScriptCore (12603 - 12603.3.8) <9557271A-1838-38DD-93E3-D8A9ECDE3B6B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fffbd3a7000 - 0x7fffbd3c0ff7 com.apple.Kerberos (3.0 - 1) <B9D242EB-E325-3A21-9812-C77CBBFB0D51> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fffbd3c1000 - 0x7fffbd3f7fff com.apple.LDAPFramework (2.4.28 - 194.5) <492ACA22-373E-3DD9-BAEB-9EF6AA962FD5> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fffbd64a000 - 0x7fffbd650fff com.apple.MediaAccessibility (1.0 - 97.1.1) <0BD82735-6644-37CE-B13D-8E7CC59A1752> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fffbd666000 - 0x7fffbdb9fff7 com.apple.MediaToolbox (1.0 - 1907.59.1.6) <FA068C6F-0506-35C3-A637-C4AFF82411DB> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fffbdba0000 - 0x7fffbdbfbfff com.apple.Metal (87.18 - 87.18) <E3618B54-C728-34CA-9E8A-9BD33A295D31> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fffbe4e4000 - 0x7fffbe4ecfff com.apple.NetFS (6.0 - 4.0) <14A24D00-5673-330A-959D-87F72040DEFF> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fffbe6c3000 - 0x7fffbe6cbff7 libcldcpuengine.dylib (2.8.5) <81563526-886E-37E4-BF85-4A6D75F93C65> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fffbe6cc000 - 0x7fffbe71aff3 com.apple.opencl (2.8.6 - 2.8.6) <E78463D3-73B6-3002-BD71-9CC1D6722968> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fffbe71b000 - 0x7fffbe734ffb com.apple.CFOpenDirectory (10.12 - 194) <A64E9A01-3F6E-36EA-9C10-88C564A68C9D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fffbe735000 - 0x7fffbe740ff7 com.apple.OpenDirectory (10.12 - 194) <4298FFD0-B1A7-3064-AF5B-708B3FA38671> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fffbe741000 - 0x7fffbe743fff libCVMSPluginSupport.dylib (14.0.16) <9E12EB67-6630-39A0-AB93-77405F5EC2A7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fffbe744000 - 0x7fffbe747ff7 libCoreFSCache.dylib (156.3) <687C4CC3-6537-344B-8BE1-5234C8CB2864> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fffbe748000 - 0x7fffbe74cfff libCoreVMClient.dylib (156.3) <E7AEFCBE-B6BF-3C7C-9A4E-E78CB04DB794> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fffbe74d000 - 0x7fffbe756ff7 libGFXShared.dylib (14.0.16) <D10C7A01-8A11-3A42-A9FA-C411AE453B27> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fffbe757000 - 0x7fffbe762fff libGL.dylib (14.0.16) <0801F3B9-A525-32BB-9BC0-478947CE21D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fffbe763000 - 0x7fffbe79fff7 libGLImage.dylib (14.0.16) <FE39C57B-056C-3CBF-B653-A8F2005631C1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fffbe7a0000 - 0x7fffbe916ff3 libGLProgrammability.dylib (14.0.16) <A95F26AD-D496-3581-A310-5131F61CFB4A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fffbe917000 - 0x7fffbe958ff7 libGLU.dylib (14.0.16) <B285EAD6-B3AA-3753-BB85-75864BD6E76C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fffbf2c0000 - 0x7fffbf2cefff com.apple.opengl (14.0.16 - 14.0.16) <167C9883-A79E-3B7F-AFED-8CD6683B291D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fffbf36b000 - 0x7fffbf4b2fff com.apple.QTKit (7.7.3 - 2978.7) <49F88771-52FE-3989-AAB7-10A7494C4419> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fffbf4b3000 - 0x7fffbf71dff7 com.apple.imageKit (3.0 - 1023) <9C547565-CBAA-3ACB-A3F6-1366A0DCDCB4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fffbf71e000 - 0x7fffbf7e5fff com.apple.PDFKit (1.0 - 1) <BE82F14C-B20C-3771-B16C-F0723F6552AD> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fffbf7e6000 - 0x7fffbfd0cff7 com.apple.QuartzComposer (5.1 - 356) <C66293F6-EF05-3B36-8524-081CEB9FADD7> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fffbfd0d000 - 0x7fffbfd30ffb com.apple.quartzfilters (1.10.0 - 1.10.0) <365342ED-7A1A-3C75-AE60-90764E96034C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fffbfd31000 - 0x7fffbfe1efff com.apple.QuickLookUIFramework (5.0 - 720.7) <3136C23E-399E-3296-928A-B18EC9FC423C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fffbfe1f000 - 0x7fffbfe1ffff com.apple.quartzframework (1.5 - 21) <09455972-8A33-3D61-B193-BA7E7CF984CA> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fffbfe20000 - 0x7fffc0020fff com.apple.QuartzCore (1.11 - 453.39.4) <A45AFBC4-87D4-3533-A0AC-1D6629C77984> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fffc0021000 - 0x7fffc0076fff com.apple.QuickLookFramework (5.0 - 720.7) <3BD7BA2F-924C-3EFF-B26E-3F930E62E6B4> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fffc0077000 - 0x7fffc008cfff com.apple.SafariServices.framework (12603 - 12603.3.8) <966BF0C8-B94B-3BDF-AFE1-0F99DAAE6D99> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fffc0587000 - 0x7fffc0889ff7 com.apple.security (7.0 - 57740.60.18) <005E8C96-40B6-35E3-B58B-888A5F5957C2> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fffc088a000 - 0x7fffc08fffff com.apple.securityfoundation (6.0 - 55132.50.7) <15C53957-A9DE-31AE-A192-949244F47CD7> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fffc0900000 - 0x7fffc0929fff com.apple.securityinterface (10.0 - 55079.50.4) <C9B0E11A-362B-3C0D-8B2E-B06510BCE20A> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fffc092a000 - 0x7fffc092dff3 com.apple.xpc.ServiceManagement (1.0 - 1) <BE0F9708-0B55-3E78-A15E-C287B8ED13BA> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fffc0cb4000 - 0x7fffc0d23ff7 com.apple.SystemConfiguration (1.14 - 1.14) <3FFD3930-B307-3E31-9FA6-12221EB0F969> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fffc0d24000 - 0x7fffc10d2fff com.apple.VideoToolbox (1.0 - 1907.59.1.6) <EB2577A4-DCDF-3FD1-B5FA-42A55653A74D> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fffc2dff000 - 0x7fffc2e06ffb com.apple.APFS (1.0 - 1) <A0614DF8-56CE-3DA3-922E-769B9F975A37> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fffc357a000 - 0x7fffc3595ff3 com.apple.AppContainer (4.0 - 307.50.21) <C2E6BA3D-81FF-39C3-B4BF-DBB9A17DE078> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fffc3596000 - 0x7fffc35a3ff3 com.apple.AppSandbox (4.0 - 307.50.21) <BF9FA426-8C11-358B-9E1F-A3901E3F2B14> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fffc35a4000 - 0x7fffc35c6ffb com.apple.framework.Apple80211 (12.0 - 1200.47) <C3033EEE-771A-3664-BBDD-BE1F6D075FC7> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fffc35c7000 - 0x7fffc35d6feb com.apple.AppleFSCompression (88.50.3 - 1.0) <478E8BFF-8BA2-375E-BE02-BA27F115C15A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fffc36c4000 - 0x7fffc374f97f com.apple.AppleJPEG (1.0 - 1) <B9E9570D-04A4-34E4-B756-D200043B25B8> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fffc3763000 - 0x7fffc377efff com.apple.aps.framework (4.0 - 4.0) <6CA07CDF-1E35-34E9-95BF-BD565FF42BAD> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fffc377f000 - 0x7fffc3787ffb com.apple.AppleSRP (5.0 - 1) <6AAE93B6-9816-35B2-9C59-D5C3218065AF> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fffc3788000 - 0x7fffc378bff3 com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <42A1731A-A576-307A-B07C-9F8F64696CB7> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fffc378c000 - 0x7fffc37defff com.apple.AppleVAFramework (5.0.36 - 5.0.36) <7352078D-C230-397C-81A5-57A48CF218C0> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fffc37e8000 - 0x7fffc37efff7 com.apple.AssetCacheServices (48.3 - 48.3) <C59F7295-36D8-3109-A910-C83D884CC92C> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
0x7fffc3b82000 - 0x7fffc3c00ff7 com.apple.backup.framework (1.8.5 - 1.8.5) <CC679891-E8F5-3166-8EB6-AEA06954A52D> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fffc3c29000 - 0x7fffc3c66ffb com.apple.bom (14.0 - 194.1) <0CBECAF1-B5E0-302F-99EC-D7ED14E12B84> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fffc3ea7000 - 0x7fffc3ed0ffb com.apple.CacheDelete (1.0 - 1) <D9678282-6F34-3EE4-94E2-42B2F6A055A5> /System/Library/PrivateFrameworks/CacheDelete.framework/Versions/A/CacheDelete
0x7fffc429c000 - 0x7fffc42c3fff com.apple.CalendarAgentLink (8.0 - 250) <E50E29F6-2BAB-3B8B-BBEA-7DC0B8B077AD> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink
0x7fffc488b000 - 0x7fffc48b2ff3 com.apple.ChunkingLibrary (173 - 173) <FC2165F9-FC93-39C0-8323-C2F43A5E00A3> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fffc48b3000 - 0x7fffc493fff7 com.apple.CloudDocs (1.0 - 486.29) <392B87EC-0317-313F-8FE2-F571831C7F35> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fffc51d7000 - 0x7fffc51e0ffb com.apple.CommonAuth (4.0 - 2.0) <216950CB-269F-3476-BA17-D6363AC49FBC> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fffc52a7000 - 0x7fffc52f8ff7 com.apple.AddressBook.ContactsFoundation (8.0 - 2250.11) <1324A70E-A093-3DB9-A802-07B8F4A499B5> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x7fffc52f9000 - 0x7fffc531bfff com.apple.contacts.ContactsPersistence (1.0 - 2250.11) <7CDEB852-B3B7-328F-9537-DFB3A58B882C> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
0x7fffc5365000 - 0x7fffc5744ff7 com.apple.CoreAUC (226.0.0 - 226.0.0) <FBF6C5BC-5937-3957-B6BA-E101DF9B0DF6> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fffc5745000 - 0x7fffc5775fff com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <3F6857D1-AE7C-3593-B064-930F5BB7269E> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fffc5810000 - 0x7fffc5818ffb com.apple.frameworks.CoreDaemon (1.3 - 1.3) <2AB86FAF-37B3-3323-9EF0-CA591B6E357C> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fffc5929000 - 0x7fffc5939fff com.apple.CoreEmoji (1.0 - 40.3.3) <E9A28301-2D79-3A97-A046-028258A6ABE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fffc59fe000 - 0x7fffc5a14ff3 com.apple.CoreMediaAuthoring (2.2 - 956) <AEBFF55F-BF1E-3CA5-AA9C-1CE22218A665> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fffc5a1b000 - 0x7fffc5aabffb com.apple.CorePDF (4.0 - 4) <7F50E4A6-940C-33F5-BE4E-7E01AFE98A8F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fffc5c74000 - 0x7fffc5ca4ff3 com.apple.CoreServicesInternal (276.2 - 276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fffc5f35000 - 0x7fffc5fc4ff7 com.apple.CoreSymbolication (62046) <7839CD8E-011D-3567-88DE-3D472C661136> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fffc5fc5000 - 0x7fffc6104fe7 com.apple.coreui (2.1 - 431.3) <2E8FEC10-FC5B-3782-92DA-A85C24B7BF7C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fffc6105000 - 0x7fffc61d5ff3 com.apple.CoreUtils (5.1 - 510.31) <E68BB8ED-8874-36EC-A7C5-1017C0E727CB> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fffc6225000 - 0x7fffc628aff3 com.apple.framework.CoreWiFi (12.0 - 1200.31) <DF0972EF-F817-3FD3-8C00-2D57B8738D8C> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fffc628b000 - 0x7fffc6299ff7 com.apple.CrashReporterSupport (10.12 - 827) <802A9B81-E349-348B-90AB-10E40B654250> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fffc630b000 - 0x7fffc6315ffb com.apple.framework.DFRFoundation (1.0 - 104.25) <7CFF896C-EF22-3941-BB3D-F3615CE4C908> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fffc6316000 - 0x7fffc631aff3 com.apple.DSExternalDisplay (3.1 - 380) <4B5E3FF0-E8C3-38CC-BF72-418C928956AB> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fffc6350000 - 0x7fffc63c5ffb com.apple.datadetectorscore (7.0 - 539.1) <74595F6C-8283-3C73-9F56-C6FA957F8B94> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fffc6401000 - 0x7fffc6440fff com.apple.DebugSymbols (137 - 137) <58A70B66-2628-3CFE-B103-2200D95FC5F7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fffc6441000 - 0x7fffc6552fff com.apple.desktopservices (1.11.5 - 1.11.5) <46A9D4F3-1EF8-373C-98A4-AD48D285E484> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fffc6557000 - 0x7fffc662cfff com.apple.DiskImagesFramework (444.50.16 - 444.50.16) <85BC24F9-3DF7-3AFC-B953-DE2CC94D61E9> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fffc6695000 - 0x7fffc66a0fff com.apple.DisplayServicesFW (3.1 - 380) <0BDF6C17-5E5F-33F8-8E99-C7350C6F9667> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fffc66e5000 - 0x7fffc66e7ffb com.apple.EFILogin (2.0 - 2) <A74B0065-643F-3BC1-8FE9-E7CEAA29AD9A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fffc683a000 - 0x7fffc6c6bff7 com.apple.vision.FaceCore (3.3.2 - 3.3.2) <9391D5A3-738C-3136-9D07-518CB43DBADA> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fffc6ca9000 - 0x7fffc703bff7 com.apple.FinderKit (1.5.5 - 1.5.5) <85D64484-35E0-3500-A651-FD1DD9A1D6C5> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
0x7fffc7fc2000 - 0x7fffc7fc2fff libmetal_timestamp.dylib (600.0.49.9) <E5EED927-1671-3390-BCBB-D76201D63C73> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fffc7fcf000 - 0x7fffc7fdaff3 libGPUSupportMercury.dylib (14.0.16) <7EE3DA75-2F9D-3C6D-AECD-F73EA47BE81B> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fffc8293000 - 0x7fffc82affff com.apple.GenerationalStorage (2.0 - 267.1) <3DE1C580-D089-362D-8582-8DE68A3C5F13> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fffc82c8000 - 0x7fffc897afff com.apple.GeoServices (1.0 - 1228.24.9.30.34) <96BF97F6-8FF2-3FC4-A8C1-498CB7B0D9A0> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fffc89c0000 - 0x7fffc8a36ff3 com.apple.Heimdal (4.0 - 2.0) <8F9C9041-66D5-36C9-8A4C-1658035C311D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fffc8a37000 - 0x7fffc8a48fff com.apple.HelpData (2.1.12 - 100.1) <EEB8CC44-9AFF-3005-A25D-18FE46574FD5> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fffc9051000 - 0x7fffc9058ffb com.apple.IOAccelerator (311.14 - 311.14) <278124AF-02DC-3785-9FA9-14EDB8E5FD56> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fffc905a000 - 0x7fffc906eff7 com.apple.IOPresentment (1.0 - 29.10) <30DF04EE-10E2-353F-845F-A97B87DF3207> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fffc906f000 - 0x7fffc9091fff com.apple.IconServices (74.4 - 74.4) <218DDD05-35F4-3833-B98D-471ED0EBC031> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fffc912d000 - 0x7fffc913dff3 com.apple.IntlPreferences (2.0 - 216) <77C9C2E7-EF9F-34BB-A5E3-B8BEA4226B5F> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fffc9178000 - 0x7fffc932ffff com.apple.LanguageModeling (1.0 - 123.2.5) <A8CA965F-0399-310D-91C3-B93DDDE9A442> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fffc937b000 - 0x7fffc937fff7 com.apple.LoginUICore (4.0 - 4.0) <7ADA40B1-995C-3947-8163-2257E7FB9440> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fffc942b000 - 0x7fffc94edff3 com.apple.MMCS (1.3 - 385.4) <D3D76CE0-DE05-373E-B757-9E4B4920565D> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
0x7fffc999f000 - 0x7fffc99a2fff com.apple.Mangrove (1.0 - 1) <98814966-FD65-302B-B47E-00928DC34E5C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fffc9a7b000 - 0x7fffc9aafff3 com.apple.MediaKit (16 - 845) <883DC63F-F90F-3FB9-8C23-9CECD72EBCDE> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fffc9c50000 - 0x7fffc9cc9ff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <C323FC94-FFA5-3EE6-B2AC-7E61EA92F304> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fffc9e2d000 - 0x7fffc9e3bfff com.apple.MobileKeyBag (2.0 - 1.0) <D0983DB7-EF9D-3E19-A084-21319ECE5846> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fffc9e4c000 - 0x7fffc9e74ff7 com.apple.MultitouchSupport.framework (368.16 - 368.16) <9E602B4A-22CD-3CF3-B284-78D5123C9AE8> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fffc9f26000 - 0x7fffc9f31fff com.apple.NetAuth (6.2 - 6.2) <97F487D6-8089-31A8-B68C-6C1EAC6ED1B5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fffca37e000 - 0x7fffca380fff com.apple.OAuth (25 - 25) <D6E5F36D-71B8-3E12-9601-CE2A1D6ED60B> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
0x7fffca809000 - 0x7fffca84aff3 com.apple.PerformanceAnalysis (1.148.3 - 148.3) <4E468BC7-F863-3674-909D-417231EB8C28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fffca88d000 - 0x7fffca894ff3 com.apple.phonenumbers (1.1.1 - 105) <B8EFDDD3-BA26-39B8-9EA0-3649184BF527> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x7fffcae82000 - 0x7fffcaea4fff com.apple.pluginkit.framework (1.0 - 1) <775E1168-9A28-34EC-AACD-B73803B9DDD4> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
0x7fffcaef7000 - 0x7fffcaf31ffb com.apple.ProtectedCloudStorage (1.0 - 1) <8B32A7EC-D371-38E3-A286-F1BE1307F1E1> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fffcaf32000 - 0x7fffcaf4cfff com.apple.ProtocolBuffer (1 - 249.1) <A1F1B0F3-078F-378F-A9A9-0DEEA70E816A> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fffcaf4d000 - 0x7fffcaf5cff7 com.apple.QuickLookThumbnailing (1.0 - 1) <173EE873-1700-3FCA-9782-C060FBB5BCAD> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fffcaf65000 - 0x7fffcaf88ff3 com.apple.RemoteViewServices (2.0 - 124) <6B967FDA-6591-302C-BA0A-76C4856E584E> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fffcbc52000 - 0x7fffcbc55fff com.apple.SecCodeWrapper (4.0 - 307.50.21) <F8E957B2-D3F0-3B73-B38C-AE8868F00939> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fffcbce4000 - 0x7fffcbd71fff com.apple.Sharing (696.2.67 - 696.2.67) <F681EE28-153F-3216-97A6-6F5E4148AB2E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fffcbd72000 - 0x7fffcbd91ff7 com.apple.shortcut (2.16 - 98) <6C0435B1-83DD-3254-B0D3-3B86C6CE606A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fffcbd92000 - 0x7fffcbff8feb com.apple.SkyLight (1.600.0 - 170.3) <38AC05EF-3A9E-3E3E-9849-04E0223DF7B9> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fffcc1d7000 - 0x7fffcc1e3ff7 com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <684BD1EA-8268-331C-A5A9-080EB375C658> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fffcc56d000 - 0x7fffcc5cefff com.apple.Suggestions (6.0 - 197) <9DD142A2-82A5-3202-B36C-20E19B4C5D56> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
0x7fffcc8cf000 - 0x7fffcc943fdf com.apple.Symbolication (62048.1) <1A30ED19-7532-3F46-9DD3-9879A973D0CF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fffccb63000 - 0x7fffccb8fff3 com.apple.framework.SystemAdministration (1.0 - 1.0) <CD5B74B1-01ED-369E-AB11-1DA59F2C2A24> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fffccd82000 - 0x7fffccd88ff7 com.apple.TCC (1.0 - 1) <911B534B-4AC7-34E4-935E-E42ECD008CBC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fffcce14000 - 0x7fffccedaff7 com.apple.TextureIO (2.8 - 2.8) <3D61E533-4156-3B21-B7ED-CB823E680DFC> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fffccf23000 - 0x7fffccf38ff3 com.apple.ToneKit (1.0 - 1) <B709293D-0A79-398A-8AA9-50F6340C227C> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
0x7fffccf39000 - 0x7fffccf47ffb com.apple.ToneLibrary (1.0 - 1) <F2ED5DFC-5F11-3012-BCD7-17753413141F> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
0x7fffccf4e000 - 0x7fffccf4ffff com.apple.TrustEvaluationAgent (2.0 - 28.50.1) <EBE65DD5-1732-3747-8C6C-7BECEBF089A4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fffccf50000 - 0x7fffcd0e0ff3 com.apple.UIFoundation (1.0 - 490.7) <2A3063FE-1790-3510-8A0E-AEC581D42B7E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fffcdbaf000 - 0x7fffcdc6ffff com.apple.ViewBridge (283 - 283) <25A635B3-C87C-3D3A-ADF3-539713FA1048> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fffce0ba000 - 0x7fffce0c0fff com.apple.XPCService (2.0 - 1) <4B28B225-2105-33F4-9ED0-F04288FF4FB1> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fffce191000 - 0x7fffce193ffb com.apple.loginsupport (1.0 - 1) <F3140B97-12C3-35A7-9D3D-43DA2D13C113> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fffce1bf000 - 0x7fffce1e6ff7 com.apple.contacts.vCard (1.0 - 2250.11) <DD615DAF-AF34-3AB4-9CB4-DA0A882D59A5> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
0x7fffce1e8000 - 0x7fffce203ff7 libCRFSuite.dylib (34) <F78B7F5F-0B4F-35C6-AA2F-84EE9CB22137> /usr/lib/libCRFSuite.dylib
0x7fffce204000 - 0x7fffce20ffff libChineseTokenizer.dylib (21) <0886E908-A825-36AF-B94B-2361FD8BC2A1> /usr/lib/libChineseTokenizer.dylib
0x7fffce210000 - 0x7fffce2a0ff7 libCoreStorage.dylib (540.30.1) <85C0A366-F901-36E3-854A-FE8A14A04A72> /usr/lib/libCoreStorage.dylib
0x7fffce2a1000 - 0x7fffce2a2ff3 libDiagnosticMessagesClient.dylib (102) <84A04D24-0E60-3810-A8C0-90A65E2DF61A> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fffce2a3000 - 0x7fffce4b6fff libFosl_dynamic.dylib (16.39) <E22A4243-D148-3C74-BA15-2D906A3D1F9E> /usr/lib/libFosl_dynamic.dylib
0x7fffce4d2000 - 0x7fffce4d9fff libMatch.1.dylib (27) <70D4BD2A-9383-37F2-B0D6-9B592D236601> /usr/lib/libMatch.1.dylib
0x7fffce4da000 - 0x7fffce4dafff libOpenScriptingUtil.dylib (172) <90743888-C1E8-34E3-924E-1A754B2B63B9> /usr/lib/libOpenScriptingUtil.dylib
0x7fffce4db000 - 0x7fffce4dfffb libScreenReader.dylib (477.40.6) <CBE6420C-EF60-3ACD-A0B6-7CBE936BA3B8> /usr/lib/libScreenReader.dylib
0x7fffce4e0000 - 0x7fffce4e1ffb libSystem.B.dylib (1238.60.2) <F18AC1E7-C6F1-34B1-8069-BE571B3231D4> /usr/lib/libSystem.B.dylib
0x7fffce54d000 - 0x7fffce578ff3 libarchive.2.dylib (41.70.1) <A3FA7D6E-3D68-3524-8B48-EB2ECA44B13B> /usr/lib/libarchive.2.dylib
0x7fffce579000 - 0x7fffce5f5fc7 libate.dylib (1.12.13) <D0767875-D02E-3377-84D8-5F174C27BEA9> /usr/lib/libate.dylib
0x7fffce5f9000 - 0x7fffce5f9ff3 libauto.dylib (187) <34388D0B-C539-3C1B-9408-2BC152162E43> /usr/lib/libauto.dylib
0x7fffce5fa000 - 0x7fffce60aff3 libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
0x7fffce60b000 - 0x7fffce619ff7 libbz2.1.0.dylib (38) <ADFA329A-DCE7-356D-8F09-A3168DFC6610> /usr/lib/libbz2.1.0.dylib
0x7fffce61a000 - 0x7fffce670ff7 libc++.1.dylib (307.5) <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C> /usr/lib/libc++.1.dylib
0x7fffce671000 - 0x7fffce69aff7 libc++abi.dylib (307.4) <BC271AD3-831B-362A-9DA7-E8C51F285FE4> /usr/lib/libc++abi.dylib
0x7fffce69b000 - 0x7fffce6abffb libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
0x7fffce6ac000 - 0x7fffce6c2fcf libcompression.dylib (39) <F2726F95-F54E-3B21-BCB5-F7151DEFDC2F> /usr/lib/libcompression.dylib
0x7fffce6c3000 - 0x7fffce6c3ff7 libcoretls.dylib (121.50.4) <64B1001E-10F6-3542-A3B2-C4B49F51817F> /usr/lib/libcoretls.dylib
0x7fffce6c4000 - 0x7fffce6c5ff3 libcoretls_cfhelpers.dylib (121.50.4) <1A10303E-5EB0-3C7C-9165-021FCDFD934D> /usr/lib/libcoretls_cfhelpers.dylib
0x7fffce77f000 - 0x7fffce864ff7 libcrypto.0.9.8.dylib (64.50.6) <D34E16A7-990A-37A9-933A-DFAA46554EAA> /usr/lib/libcrypto.0.9.8.dylib
0x7fffce9f6000 - 0x7fffcea01fff libcsfde.dylib (540.30.1) <0C2B183B-16D9-3D5F-962D-0A09C7063211> /usr/lib/libcsfde.dylib
0x7fffcea02000 - 0x7fffcea55ff7 libcups.2.dylib (450) <9950BFCB-7882-33C9-9ECF-CE66773C5657> /usr/lib/libcups.2.dylib
0x7fffcea56000 - 0x7fffceaa8fff libcurl.4.dylib (95.70.1) <8987EFA8-0BF6-3E2A-8F04-7BD5803B9A37> /usr/lib/libcurl.4.dylib
0x7fffceaa9000 - 0x7fffceab0ff3 libdscsym.dylib (148.3) <EF99B991-18D9-3A73-BE88-4DC55F036DEF> /usr/lib/libdscsym.dylib
0x7fffcead2000 - 0x7fffcead2fff libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
0x7fffceae2000 - 0x7fffceae7ff7 libheimdal-asn1.dylib (498.50.8) <A40E3196-235E-34CE-AD9A-8D1AFC5DE004> /usr/lib/libheimdal-asn1.dylib
0x7fffceae8000 - 0x7fffcebdaff7 libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
0x7fffcebdb000 - 0x7fffcee00ffb libicucore.A.dylib (57166.0.1) <CCD2ED24-3071-383B-925D-8D763BB12A6F> /usr/lib/libicucore.A.dylib
0x7fffcee06000 - 0x7fffcee07fff liblangid.dylib (126) <2085E7A7-9A34-3735-87F4-F174EF8EABF0> /usr/lib/liblangid.dylib
0x7fffcee08000 - 0x7fffcee21ffb liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
0x7fffcee22000 - 0x7fffcee38ff7 libmarisa.dylib (5) <9030D214-5D0F-30CB-AC03-902C63909362> /usr/lib/libmarisa.dylib
0x7fffcee39000 - 0x7fffcf0e1ff7 libmecabra.dylib (744.8) <D429FCC9-42A4-38B3-8784-44024BC859EF> /usr/lib/libmecabra.dylib
0x7fffcf114000 - 0x7fffcf18eff3 libnetwork.dylib (856.60.1) <191E99F5-4723-3180-8013-02AF2F9AE4B8> /usr/lib/libnetwork.dylib
0x7fffcf18f000 - 0x7fffcf561047 libobjc.A.dylib (709.1) <70614861-0340-32E2-85ED-FE65759CDFFA> /usr/lib/libobjc.A.dylib
0x7fffcf562000 - 0x7fffcf563fff libodfde.dylib (23.50.1) <744F1E66-11EB-3A4D-8944-722F39C55278> /usr/lib/libodfde.dylib
0x7fffcf564000 - 0x7fffcf568fff libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
0x7fffcf569000 - 0x7fffcf59afff libpcap.A.dylib (67.60.1) <F6BC6ED6-AEE4-3520-B248-0C342636E2B0> /usr/lib/libpcap.A.dylib
0x7fffcf5b7000 - 0x7fffcf5d3ffb libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
0x7fffcf5d4000 - 0x7fffcf60dfff libsandbox.1.dylib (592.70.1) <9C428C49-9D9A-3F9F-9573-BF5202D1F933> /usr/lib/libsandbox.1.dylib
0x7fffcf60e000 - 0x7fffcf620ffb libsasl2.2.dylib (209) <32107C59-22C6-3049-B86E-9C2F85FF549B> /usr/lib/libsasl2.2.dylib
0x7fffcf621000 - 0x7fffcf622ff3 libspindump.dylib (231.3) <C7CEEB64-06F4-3ACA-AAC1-30ECA909501A> /usr/lib/libspindump.dylib
0x7fffcf623000 - 0x7fffcf771ff7 libsqlite3.dylib (254.8) <1ECF7DF7-7A07-3B4B-A63B-F4EFF6BC7ACF> /usr/lib/libsqlite3.dylib
0x7fffcf862000 - 0x7fffcf865ff7 libutil.dylib (47.30.1) <88CC63B3-0EDF-306E-9AB5-D87EBE0F3F16> /usr/lib/libutil.dylib
0x7fffcf866000 - 0x7fffcf873fff libxar.1.dylib (357) <69547C64-E811-326F-BBED-490C6361BDCB> /usr/lib/libxar.1.dylib
0x7fffcf874000 - 0x7fffcf963fff libxml2.2.dylib (30.17) <D4C3E467-37C6-34DE-8A1B-E7BFC29985E9> /usr/lib/libxml2.2.dylib
0x7fffcf964000 - 0x7fffcf98dfff libxslt.1.dylib (15.9) <00735AD5-B62D-3E83-86AC-5533E4E2B102> /usr/lib/libxslt.1.dylib
0x7fffcf98e000 - 0x7fffcf99fff3 libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
0x7fffcf9ae000 - 0x7fffcf9b2ff7 libcache.dylib (79) <093A4DAB-8385-3D47-A350-E20CB7CCF7BF> /usr/lib/system/libcache.dylib
0x7fffcf9b3000 - 0x7fffcf9bdfff libcommonCrypto.dylib (60092.50.5) <8A64D1B0-C70E-385C-92F0-E669079FDA90> /usr/lib/system/libcommonCrypto.dylib
0x7fffcf9be000 - 0x7fffcf9c5fff libcompiler_rt.dylib (62) <55D47421-772A-32AB-B529-1A46C2F43B4D> /usr/lib/system/libcompiler_rt.dylib
0x7fffcf9c6000 - 0x7fffcf9cefff libcopyfile.dylib (138) <819BEA3C-DF11-3E3D-A1A1-5A51C5BF1961> /usr/lib/system/libcopyfile.dylib
0x7fffcf9cf000 - 0x7fffcfa52fdf libcorecrypto.dylib (442.50.19) <65D7165E-2E71-335D-A2D6-33F78E2DF0C1> /usr/lib/system/libcorecrypto.dylib
0x7fffcfa53000 - 0x7fffcfa84fff libdispatch.dylib (703.50.37) <6582BAD6-ED27-3B30-B620-90B1C5A4AE3C> /usr/lib/system/libdispatch.dylib
0x7fffcfa85000 - 0x7fffcfa8affb libdyld.dylib (433.5) <9B2AC56D-107C-3541-A127-9094A751F2C9> /usr/lib/system/libdyld.dylib
0x7fffcfa8b000 - 0x7fffcfa8bffb libkeymgr.dylib (28) <7AA011A9-DC21-3488-BF73-3B5B14D1FDD6> /usr/lib/system/libkeymgr.dylib
0x7fffcfa8c000 - 0x7fffcfa98fff libkxld.dylib (3789.70.16) <BD02EF3F-6E09-3A64-AB21-553D5B1D2859> /usr/lib/system/libkxld.dylib
0x7fffcfa99000 - 0x7fffcfa99fff liblaunch.dylib (972.70.1) <B856ABD2-896E-3DE0-B2C8-146A6AF8E2A7> /usr/lib/system/liblaunch.dylib
0x7fffcfa9a000 - 0x7fffcfa9fff3 libmacho.dylib (898) <17D5D855-F6C3-3B04-B680-E9BF02EF8AED> /usr/lib/system/libmacho.dylib
0x7fffcfaa0000 - 0x7fffcfaa2ff3 libquarantine.dylib (85.50.1) <12448CC2-378E-35F3-BE33-9DC395A5B970> /usr/lib/system/libquarantine.dylib
0x7fffcfaa3000 - 0x7fffcfaa4ffb libremovefile.dylib (45) <38D4CB9C-10CD-30D3-8B7B-A515EC75FE85> /usr/lib/system/libremovefile.dylib
0x7fffcfaa5000 - 0x7fffcfabdff7 libsystem_asl.dylib (349.50.5) <096E4228-3B7C-30A6-8B13-EC909A64499A> /usr/lib/system/libsystem_asl.dylib
0x7fffcfabe000 - 0x7fffcfabeff7 libsystem_blocks.dylib (67) <10DC5404-73AB-35B3-A277-A8AFECB476EB> /usr/lib/system/libsystem_blocks.dylib
0x7fffcfabf000 - 0x7fffcfb4cfef libsystem_c.dylib (1158.50.2) <E5AE5244-7D0C-36AC-8BB6-C7AE7EA52A4B> /usr/lib/system/libsystem_c.dylib
0x7fffcfb4d000 - 0x7fffcfb50ffb libsystem_configuration.dylib (888.60.2) <BECC01A2-CA8D-31E6-BCDF-D452965FA976> /usr/lib/system/libsystem_configuration.dylib
0x7fffcfb51000 - 0x7fffcfb54fff libsystem_coreservices.dylib (41.4) <7D26DE79-B424-3450-85E1-F7FAB32714AB> /usr/lib/system/libsystem_coreservices.dylib
0x7fffcfb55000 - 0x7fffcfb6dfff libsystem_coretls.dylib (121.50.4) <EC6FCF07-DCFB-3A03-9CC9-6DD3709974C6> /usr/lib/system/libsystem_coretls.dylib
0x7fffcfb6e000 - 0x7fffcfb74fff libsystem_dnssd.dylib (765.50.9) <CC960215-0B1B-3822-A13A-3DDE96FA796F> /usr/lib/system/libsystem_dnssd.dylib
0x7fffcfb75000 - 0x7fffcfb9eff7 libsystem_info.dylib (503.50.4) <611DB84C-BF70-3F92-8702-B9F28A900920> /usr/lib/system/libsystem_info.dylib
0x7fffcfb9f000 - 0x7fffcfbc1ff7 libsystem_kernel.dylib (3789.70.16) <34B1F16C-BC9C-3C5F-9045-0CAE91CB5914> /usr/lib/system/libsystem_kernel.dylib
0x7fffcfbc2000 - 0x7fffcfc09fe7 libsystem_m.dylib (3121.6) <86D499B5-BBDC-3D3B-8A4E-97AE8E6672A4> /usr/lib/system/libsystem_m.dylib
0x7fffcfc0a000 - 0x7fffcfc28ff7 libsystem_malloc.dylib (116.50.8) <A3D15F17-99A6-3367-8C7E-4280E8619C95> /usr/lib/system/libsystem_malloc.dylib
0x7fffcfc29000 - 0x7fffcfc82ffb libsystem_network.dylib (856.60.1) <369D0221-56CA-3C3E-9EDE-94B41CAE77B7> /usr/lib/system/libsystem_network.dylib
0x7fffcfc83000 - 0x7fffcfc8cff3 libsystem_networkextension.dylib (563.60.2) <B021F2B3-8A75-3633-ABB0-FC012B8E9B0C> /usr/lib/system/libsystem_networkextension.dylib
0x7fffcfc8d000 - 0x7fffcfc96ff3 libsystem_notify.dylib (165.20.1) <B8160190-A069-3B3A-BDF6-2AA408221FAE> /usr/lib/system/libsystem_notify.dylib
0x7fffcfc97000 - 0x7fffcfc9ffe7 libsystem_platform.dylib (126.50.8) <897462FD-B318-321B-A554-E61982630F7E> /usr/lib/system/libsystem_platform.dylib
0x7fffcfca0000 - 0x7fffcfcaaff7 libsystem_pthread.dylib (218.60.3) <B8FB5E20-3295-39E2-B5EB-B464D1D4B104> /usr/lib/system/libsystem_pthread.dylib
0x7fffcfcab000 - 0x7fffcfcaeff7 libsystem_sandbox.dylib (592.70.1) <4B92EC49-ACD0-36AE-B07A-A2B8152EAF9D> /usr/lib/system/libsystem_sandbox.dylib
0x7fffcfcaf000 - 0x7fffcfcb0ff3 libsystem_secinit.dylib (24.50.4) <F78B847B-3565-3E4B-98A6-F7AD40392E2D> /usr/lib/system/libsystem_secinit.dylib
0x7fffcfcb1000 - 0x7fffcfcb8ffb libsystem_symptoms.dylib (532.50.47) <3390E07C-C1CE-348F-ADBD-2C5440B45EAA> /usr/lib/system/libsystem_symptoms.dylib
0x7fffcfcb9000 - 0x7fffcfcccff7 libsystem_trace.dylib (518.70.1) <AC63A7FE-50D9-3A30-96E6-F6B7FF16E465> /usr/lib/system/libsystem_trace.dylib
0x7fffcfccd000 - 0x7fffcfcd2ffb libunwind.dylib (35.3) <3D50D8A8-C460-334D-A519-2DA841102C6B> /usr/lib/system/libunwind.dylib
0x7fffcfcd3000 - 0x7fffcfcfcff7 libxpc.dylib (972.70.1) <BF896DF0-D8E9-31A8-A4B3-01120BFEEE52> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 1886
thread_create: 0
thread_set_state: 70
VM Region Summary:
ReadOnly portion of Libraries: Total=335.8M resident=0K(0%) swapped_out_or_unallocated=335.8M(100%)
Writable regions: Total=254.8M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=254.8M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 256K 3
Activity Tracing 256K 2
CG backing stores 6608K 5
CG image 468K 48
CoreAnimation 13.2M 22
CoreUI image data 5212K 31
CoreUI image file 340K 7
Foundation 24.7M 5
Image IO 12K 2
Kernel Alloc Once 8K 2
MALLOC 175.6M 67
MALLOC guard page 48K 10
Memory Tag 242 12K 2
Memory Tag 251 56K 5
STACK GUARD 56.0M 12
Stack 13.1M 12
VM_ALLOCATE 236K 21
__DATA 41.9M 302
__GLSLBUILTINS 2588K 2
__IMAGE 528K 2
__LINKEDIT 116.4M 10
__TEXT 219.4M 301
__UNICODE 556K 2
mapped file 121.2M 38
shared memory 16.4M 16
TOTAL 814.6M 904
Model: MacBookPro11,3, BootROM MBP112.0138.B40, 4 processors, Intel Core i7, 2,8 GHz, 16 GB, SMC 2.19f12
Graphics: Intel Iris Pro, Intel Iris Pro, Built-In
Graphics: NVIDIA GeForce GT 750M, NVIDIA GeForce GT 750M, PCIe, 2048 MB
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
AirPort: spairport_wireless_card_type_airport_extreme , Broadcom BCM43xx 1.0
Bluetooth: Version 5.0.5f1, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Network Service: iPhone, Ethernet, en6
Serial ATA Device: APPLE SSD SM1024F, 1 TB
USB Device: USB 3.0 Bus
USB Device: Apple Internal Keyboard / Trackpad
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: iPhone
Thunderbolt Bus: MacBook Pro, Apple Inc., 17.1
Message 5 of 8
tnydwrds
Sadly no, I did not find a workaround. Ultimately I just moved on to other engine options.
It's kind of a shame as Stringray seemed really interesting. I considered attempting to get source access (for this and other reasons), but even on Windows it looked like the official dev env was an earlier version of Visual Studio than what I had. I'm more of a Apple user visiting the Windows world and I imagine Stingray is more targeted to the opposite direction. So I mostly just took the L and moved on.
I haven't tried Stringray 1.9, so don't know if that has an updated package server that addresses the issue. I did review the release notes, but didn't see anything. Sadly no one from Autodesk ever acknowledged this either. So I don't know if we're missing something that will be obvious in hindsight or the 2 people trying to use Stringray on iOS aren't worth the effort.
The only other thing I can think of to try is supply your own entitlements file. But based on what I _think_ is happening I don't think that would work.
Sorry. I hope you have better luck and end up getting traction. Please do update this thread if/when you do.
Message 6 of 8
in reply to: tnydwrds
When i updated to Stingray 1.9 seems to have resolved this issue.
Message 7 of 8
tnydwrds
Thanks! That is great to hear.
Message 8 of 8
Well, it seems like a complicated problem, and given the situation that it correlates with the iOS, you could try to use any iOS system repair tools to fix it. If it works, please give me a reply, thanks.
