How to create linear strip lights in an evening setting
reddymade
reddymade
I'm trying to create a setting that's in the evening so the room/space is darker but I can't figure out how to change that. There are no spotlights on but seem there's a default light.
Also, I'm trying to create linear strip lights, like under the stair treads to show the illumination of steps or under the handrail but I can't figure that out either. All I see are spotlights or omni lights. I work in 3dsmax with vray. I imported the handrail with a vray light material which shows the light but not the illumination itself that shines on the steps.
Any help would be greatly appreciated.
Thank you,
David
Replies (7)
hagen.deloss
Hi @reddymade
Great to hear from you on the forums! Did you have to convert the V-Ray lights to import into Interactive? I know there's a way to create a day/night cycle using 3DS Max Interactive, because I have seen @gustavo.bergoya create some pretty awesome Interactive experiences.
Gustavo, do you have any insights into changing the word lighting to a night scene inside Max Interactive?
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
gustavo.bergoya
Hi Hagen and Reddymade
Attached I sent a video that shows a small example of lighting in 3ds Max Interactive. Then I can if you want to send them another video that shows how to make the animation of all the elements of the scene.
I applied:
1 - Directional Light
2 - Spotlight
3 - Material emissive
4 - Clouds plugin
regards
BenBisares
Autodesk Support
Autodesk Support
I created a video showing how to create the effect of strip lights and also change the global lighting effects to make it look more like evening
https://autode.sk/2BdMhPv
Long story short, use emissive shaders
EDIT:
Looks like Gustavo beat me to it! I'll leave my post here regardless as there's no such thing as too many videos?
Ben Bisares
gustavo.bergoya
Thanks Ben,
This is a good example
reddymade
I'm sorry but i wasn't clear enough I assumed that this was the stingray forum that it'd be a solution for it, not 3d max. I actually meant how to create linear lights in stingray. The box light creates parallel lights but it's not realistic like a spotlight.
gustavo.bergoya
Hi Reddymade
This is Stingray... Stingray change name to 3ds Max Interactive.
I used 3ds Max Interactive and Ben used 3ds Max to export the elements to 3ds Max Interactive and create the light scene
hagen.deloss
Hi @reddymade
I wanted to follow up and see if you were able to resolve your issue using the information within @gustavo.bergoya and @BenBisares 's videos?
Do you have any follow up questions in regards to either of these workflows?
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
