Get access to Stingray Open Source Engine
I'm a student on Lulea Universityof Technology and i have two lab works left in Stingray engine that need to be finished before i can get my degree. But with stingray being shutdown, getting access to the engine proven difficult.
Is there a way for me to get access to it again?
The lab work that i have left to do is about making plugins with c++ to the Stingray engine, i already done some of them and only need to the the last once.
__ben__
Unfortunately we no longer license Stingray source.
Shanii2
you can use the Sample plugin at github and fork it to make the plugin and using widget playground to test with the editor u can use c++ and java script for creating functionalities and then tie up the editors lua binding and etc code to implement , look at other plugins Render to Texture' , Giphy' Htmlrender, cloud plugin ,camera plugin, and so others to understand how you can creat ure own java and c++ libraries to interact with editor using lua bindings.
