Control menu with Xbox controller
I know I've done this before, but I am completely drawing a blank now.  How do I allow for an Xbox controller to conrol the menu to start and exit a game?  I feel like it should be in the main_menu.lua file, but I can't figure it out.
Similarly, is there a resource like this one: http://wiki.unity3d.com/index.php/Xbox360Controller that shows how the Xbox Controller buttons map for the lua player file in Stingray?
santd
Hello @Anonymous,
I found the following post of yours that was answered by Dan Matlack:
http://forums.autodesk.com/t5/stingray/lua-script-for-xbox-control/m-p/5907611#M2224
Does that cover what you are attempting to do?
If not, could you provide more information in regards to what you are looking for.
Cheers,
David Santos
You can do it by editing the mainmenu.lua file. Scroll to the bottom and add the following:
elseif Pad1 and Pad1.active() then
	if Pad1.pressed(stingray.Pad1.button_id(Appkit.Util.plat(nil, "a", nil, "cross"))) then MainMenu.action = "start"
	elseif Pad1.pressed(stingray.Pad1.button_id(Appkit.Util.plat(nil, "y", nil, "triangle"))) then MainMenu.action = "exit"
	end
end
Here it is in context:
if MainMenu.action == nil  then
	local time = stingray.World.time(SimpleProject.world)
	local p = stingray.Application.platform()
	if time - start_time > 1 then
		if Appkit.Util.is_pc() then
			if stingray.Keyboard.pressed(stingray.Keyboard.button_id("1")) then MainMenu.action = "start"
			elseif stingray.Keyboard.pressed(stingray.Keyboard.button_id("esc")) then MainMenu.action = "exit"
				end
    			end
    		end
	end
end
