How can i blend the retargeted animation onto my character, is there a way that the retargeted animation would be blend with the animation events on respective layers of the my target Character
Solved by _robbs_. Go to Solution.
Solved by dan.matlack. Go to Solution.
Yes but before that i.m having trouble importing dummy animations, and seems to cant compile the data, its giving Data:assertion failed error and no matter how much i refresh or restart it does'nt get back it up, Ive deleted the assets from with in the engine but still no good
here they are as you can see its a dummy character from maximo ive characterist it but on importing its animations which are alsoo download, my engine keeps crashing and not compiling,.. I can still do the rest of work like in animation controller but can see anything.
log console from where teh error start
Product version: `Release (1.1.247.0)` Error context ---------------------------------------- While compiling: content/models/character/dummy character/Slip_down.character Callstack ---------------------------------------- 0x405fbc0d d:\buildagent\work\fc67a3c094ac016b\git\runtime\foundation\error\error.cpp(394): stingray::report_assert_failure 0x40a57db9 d:\buildagent\work\fc67a3c094ac016b\git\runtime\plugins\plugin_foundation\const_config.h(105): stingray_plugin_foundation::ConstConfigItem::to_integer 0x40a51aa9 d:\buildagent\work\fc67a3c094ac016b\git\runtime\plugins\humanik_plugin\hik_plugin_engine.cpp(233): humanik_plugin::compile_character 0x401d2de8 d:\buildagent\work\fc67a3c094ac016b\git\runtime\application\plugin\plugin_interface.cpp(256): plugin_interface_internal::compile_wrapper 0x4062bc69 d:\buildagent\work\fc67a3c094ac016b\git\runtime\foundation\resource\data_compiler.cpp(480): stingray::DataCompiler::compile 0x4062e82b d:\buildagent\work\fc67a3c094ac016b\git\runtime\foundation\resource\data_compiler.cpp(635): stingray::DataCompiler::compile_all_files 0x4062d088 d:\buildagent\work\fc67a3c094ac016b\git\runtime\foundation\resource\data_compiler.cpp(317): stingray::DataCompiler::compile 0x400135b9 d:\buildagent\work\fc67a3c094ac016b\git\runtime\main\windows\main_datacompiler.cpp(360): `anonymous namespace'::compile 0x400197b2 d:\buildagent\work\fc67a3c094ac016b\git\runtime\main\windows\main_datacompiler.cpp(440): `anonymous namespace'::process_compile_request 0x4000e502 d:\buildagent\work\fc67a3c094ac016b\git\runtime\main\windows\main_datacompiler.cpp(938): ::operator() 0x40600fb4 d:\buildagent\work\fc67a3c094ac016b\git\runtime\foundation\thread\thread_manager.cpp(308): stingray::ThreadManager::thread_proc 0x643413d2 BaseThreadInitThunk 0x648d5464 RtlUserThreadStart
Data / Compiler: Error compiling content/models/character/Jake_normal/jake_Tpose1-Take 001_prologue.anim_controller Failure while parsing content/models/character/Jake_normal/jake_Tpose1-Take 001_prologue.anim_controller: content/models/character/Jake_normal/jake_Tpose1-Take 001_prologue.anim_controller(2:1): Expected an object for key `compiler_data`
Data / : Assertion failed Assertion failed `is_integer()` at `D:\BuildAgent\work\fc67a3c094ac016b\git\runtime\plugins\plugin_foundation/const_config.h:105
sorry for that but i think the blog is blocking the fbx file while uploading, i think its not supported, so here's they in zip
Hi Dan.
Can you please tell me which animation layer is top most & the lowest. i cant seem to blend the animations properly, The layer marked with (B), does it becomes the top most layer that overwrites the animations below, or is it the base or lowest layer that gets suppresed/overriden by the above layers.
I was able to import your fbx with animation with no issues. However, there is a bone mismatch in the two different animations, are they from different rigs? You would want to import your mesh and skeleton first, then import animations second and make sure they match from the rig/skeleton you are using.
Thanks Dan, but i have downloaded them from maximo on same character, may be the animations are mixed up or something, i deleted all its files and the problem resolved.
Thanks for that and can you clearfy me about the animation layers
Hi again Dan,
Can you brief me about how to add constraints in animation manager, or give brief tutorial on effectively using constraints, I wanted to add Look at contraint to head joint, and also aim constraint to eye joints. I know we can add constraints using HIK constraints for head, but what for the eye joints or similar similar joints. Can you please help me out in this regard
Hi dan I now got this error and cant rectify it, and i dont know why, it occurs because i haven't did anything related to physics yet, i just terminate the engine to refresh and started over and it keeps coming, and again its preventing to compile
here's the log error, i dont know if its due to terrain physx or not,
Data / Compiler: Compiling content/levels/Prologue.level
Data / : PhysX: [internal error] cleaning the mesh failed ..\..\PhysXCooking\src\mesh\TriangleMeshBuilder.cpp 264 At `D:\BuildAgent\work\fc67a3c094ac016b\git\runtime\engine\physics\physx\physx_sdk.cpp:105` Build identifier: `aa6b52358541601f4a7b415393841a1a296b47b5` Product version: `Release (1.1.247.0)` Error context ---------------------------------------- While compiling: content/levels/Prologue.level Callstack
Thanks Dan,
Sorry for repeatidly reports, i'm actually, creating a AAA game and its has a very Fancy animaition for my character as well as the graphic contents that, im loading, such as my terrain unit is giving me alot of trouble, my engine crashes when i add undergrowth, how much density should i kept for the vegetaion meshes, and do i have to paint very less amount of the paint layer for undergrowth,
well it was autually, a mesh not a tranparency masked vegetation, its somthing like a small grass pach with its materail on, i happened to undergrowwth it on green channel, which has a nice vegetation texture, but my engine just crashes when, i zoom in , i think i should paint a little amount of paint layer which needs to have undergrowth is that right.
And thanks again
I briefly cover undergrowth toward the end of this tutorial ...
Hi again Dan , thanks for lateral help,
Im having some trouble with vfx, i cant seem to get correct uv animation for my selected spritesheet, will there be tutorial in future in setting up the animation using sprites sheets. Like this one. Please help in this regard
