Cant get model to show in texture editor
This widget could not be displayed.
I am working on a test model for a mod I am a part of and am unable to get any kind of view with the texture editor.
If i select each part of the model in turn it will show up in the editor but when I try to select the model as a whole all i get is a blank TE window.
I thought it might be the curve I have in the map but that wasnt it, as after unselecting it I still got a blank window.
using:
Mod Tool 6.1
Vista Ult. 32 bit
Is the model split into different meshes or clusters?
Also be sure to check your view preferences in the TE window - Alt+Right-Click in the TE window to make sure you don't have some funky preferences turned on...
Also, realize that if you have different UV sets on the model, you can't (AFAIK) display more than one set at a time. XSI is not like Maya in it's UV editor behavior (which I certainly appreciate)....
Also, check the UV pulldown at the top of the window to make sure you're looking at the UV set you're interested in....
