Smoke Forum
Welcome to Autodesk’s Smoke Forums. Share your knowledge, ask questions, and explore popular Smoke topics.
URGENT!! Smoke 2013 - Export miscellaneous errors - Showstopper.
2 REPLIES 2
eveofdistraction
3542 Views, 2 Replies
Hello all,
I'm coming back with new issues with Smoke 2013 and after two weeks of trying to work out solution, my IT and I decided to contact you to see if you had suggestions and/or solutions as we are encountering various difficulties with the backburner manager and exports.
Know that we mostly used this page here for troubleshooting, with no concrete results  and everything on the Service Monitor is all green.
What is odd is that depending of the timelines, I don't always encounter issues during exports.
In Smoke.
The errors includes messages such as:
  • Backburner is not installed correctly. Can't access cache and export. (I couldn't reproduce the error to get the correct message)
  • Failed to consolidate clip for timeline export.
  • For some sequence timeline, Smoke will simply freeze and here is the log I get:
Feb 10 09:15:30 : Output log to: '/usr/discreet/log/vref.log'.
Feb 10 09:15:30 :
Feb 10 09:15:30 : ---------------------------------------------------------------------------
Feb 10 09:15:30 :
Feb 10 09:15:30 : Parsing Messages XML
Feb 10 09:15:30 : Messages loaded
Feb 10 09:15:30 : Parsing Dialogs XML
Feb 10 09:15:30 : Dialogs loaded
Feb 10 09:15:30 : Registered thread 'TooltipsManager' [ 4985884672 ]
Feb 10 09:15:30 : Parsing Tooltips XML
Feb 10 09:15:30 : CIP was not initalized
Feb 10 09:15:30 : Autodesk(R) Smoke(R) Version 2013.2.53 P3357
Feb 10 09:15:30 : Autodesk and Smoke are registered trademarks or trademarks of Autodesk, Inc., and/or its subsidiaries and/or affiliates in the USA and/or other countries. All other brand names, product names, or trademarks belong to their respective holders.
Feb 10 09:15:30 : Autodesk reserves the right to alter product offerings and specifications at any time without notice, and is not responsible for typographical or graphical errors that may appear in this document. (C) 2013 Autodesk, Inc.
Feb 10 09:15:30 :
Feb 10 09:15:30 : BUILD DATE : Tue May 21 12:38:58 2013
Feb 10 09:15:30 : EXEC DATE : Fri Feb 10 09:15:30 2017 - (1486736130)
Feb 10 09:15:30 : CONFIG : /usr/discreet/smoke_2013.2.53/cfg/init.cfg
Feb 10 09:15:30 : VIDEO CONFIG: AJA_KONA3G, in format SERIAL1, out format SERIAL1
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976psf, DTVsync (1920X1080_2398SF), 8-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976psf, DTVsync (1920X1080_2398SF), 8-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976psf, DTVsync (1920X1080_2398SF), 10-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976psf, DTVsync (1920X1080_2398SF), 8-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976psf, DTVsync (1920X1080_2398SF), 10-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976psf, DTVsync (1920X1080_2398SF), 10-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976psf, DTVsync (1920X1080_2398SF), 8-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976psf, DTVsync (1920X1080_2398SF), 10-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000psf, DTVsync (1920X1080_24SF), 8-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000psf, DTVsync (1920X1080_24SF), 8-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000psf, DTVsync (1920X1080_24SF), 10-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000psf, DTVsync (1920X1080_24SF), 8-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000psf, DTVsync (1920X1080_24SF), 10-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000psf, DTVsync (1920X1080_24SF), 10-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000psf, DTVsync (1920X1080_24SF), 8-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000psf, DTVsync (1920X1080_24SF), 10-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976p, DTVsync (1920X1080_2398P), 8-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976p, DTVsync (1920X1080_2398P), 8-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976p, DTVsync (1920X1080_2398P), 10-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976p, DTVsync (1920X1080_2398P), 8-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976p, DTVsync (1920X1080_2398P), 10-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976p, DTVsync (1920X1080_2398P), 10-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976p, DTVsync (1920X1080_2398P), 8-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976p, DTVsync (1920X1080_2398P), 10-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000p, DTVsync (1920X1080_24P), 8-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000p, DTVsync (1920X1080_24P), 8-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000p, DTVsync (1920X1080_24P), 10-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000p, DTVsync (1920X1080_24P), 8-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000p, DTVsync (1920X1080_24P), 10-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000p, DTVsync (1920X1080_24P), 10-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000p, DTVsync (1920X1080_24P), 8-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000p, DTVsync (1920X1080_24P), 10-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 25000p, DTVsync (1920X1080_25P), 8-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 25000p, DTVsync (1920X1080_25P), 8-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 25000p, DTVsync (1920X1080_25P), 10-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 25000p, DTVsync (1920X1080_25P), 8-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 25000p, DTVsync (1920X1080_25P), 10-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 25000p, DTVsync (1920X1080_25P), 10-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 25000p, DTVsync (1920X1080_25P), 8-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 25000p, DTVsync (1920X1080_25P), 10-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 50i, DTVsync (1920X1080_50I), 8-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 50i, DTVsync (1920X1080_50I), 8-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 50i, DTVsync (1920X1080_50I), 10-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 50i, DTVsync (1920X1080_50I), 8-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 50i, DTVsync (1920X1080_50I), 10-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 50i, DTVsync (1920X1080_50I), 10-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 50i, DTVsync (1920X1080_50I), 8-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 50i, DTVsync (1920X1080_50I), 10-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 2997p, DTVsync (1920X1080_2997P), 8-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 2997p, DTVsync (1920X1080_2997P), 8-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 2997p, DTVsync (1920X1080_2997P), 10-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 2997p, DTVsync (1920X1080_2997P), 8-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 2997p, DTVsync (1920X1080_2997P), 10-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 2997p, DTVsync (1920X1080_2997P), 10-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 2997p, DTVsync (1920X1080_2997P), 8-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 2997p, DTVsync (1920X1080_2997P), 10-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 3000p, DTVsync (1920X1080_30P), 8-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 3000p, DTVsync (1920X1080_30P), 8-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 3000p, DTVsync (1920X1080_30P), 10-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 3000p, DTVsync (1920X1080_30P), 8-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 3000p, DTVsync (1920X1080_30P), 10-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 3000p, DTVsync (1920X1080_30P), 10-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 3000p, DTVsync (1920X1080_30P), 8-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 3000p, DTVsync (1920X1080_30P), 10-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994i, DTVsync (1920X1080_5994I), 8-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994i, DTVsync (1920X1080_5994I), 8-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994i, DTVsync (1920X1080_5994I), 10-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994i, DTVsync (1920X1080_5994I), 8-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994i, DTVsync (1920X1080_5994I), 10-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994i, DTVsync (1920X1080_5994I), 10-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994i, DTVsync (1920X1080_5994I), 8-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994i, DTVsync (1920X1080_5994I), 10-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000i, DTVsync (1920X1080_60I), 8-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000i, DTVsync (1920X1080_60I), 8-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000i, DTVsync (1920X1080_60I), 10-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000i, DTVsync (1920X1080_60I), 8-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000i, DTVsync (1920X1080_60I), 10-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000i, DTVsync (1920X1080_60I), 10-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000i, DTVsync (1920X1080_60I), 8-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000i, DTVsync (1920X1080_60I), 10-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994p, freesync (1920X1080_5994P_3G), 8-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994p, freesync (1920X1080_5994P_3G), 8-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994p, freesync (1920X1080_5994P_3G), 10-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994p, freesync (1920X1080_5994P_3G), 8-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994p, freesync (1920X1080_5994P_3G), 10-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994p, freesync (1920X1080_5994P_3G), 10-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994p, freesync (1920X1080_5994P_3G), 8-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994p, freesync (1920X1080_5994P_3G), 10-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000p, freesync (1920X1080_60P_3G), 8-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000p, freesync (1920X1080_60P_3G), 8-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000p, freesync (1920X1080_60P_3G), 10-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000p, freesync (1920X1080_60P_3G), 8-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000p, freesync (1920X1080_60P_3G), 10-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000p, freesync (1920X1080_60P_3G), 10-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000p, freesync (1920X1080_60P_3G), 8-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000p, freesync (1920X1080_60P_3G), 10-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976psf, freesync (1920X1080_2398SF), 8-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976psf, freesync (1920X1080_2398SF), 8-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976psf, freesync (1920X1080_2398SF), 10-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976psf, freesync (1920X1080_2398SF), 8-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976psf, freesync (1920X1080_2398SF), 10-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976psf, freesync (1920X1080_2398SF), 10-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976psf, freesync (1920X1080_2398SF), 8-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976psf, freesync (1920X1080_2398SF), 10-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000psf, freesync (1920X1080_24SF), 8-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000psf, freesync (1920X1080_24SF), 8-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000psf, freesync (1920X1080_24SF), 10-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000psf, freesync (1920X1080_24SF), 8-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000psf, freesync (1920X1080_24SF), 10-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000psf, freesync (1920X1080_24SF), 10-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000psf, freesync (1920X1080_24SF), 8-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 24000psf, freesync (1920X1080_24SF), 10-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 50i, freesync (1920X1080_50I), 8-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 50i, freesync (1920X1080_50I), 8-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 50i, freesync (1920X1080_50I), 10-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 50i, freesync (1920X1080_50I), 8-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 50i, freesync (1920X1080_50I), 10-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 50i, freesync (1920X1080_50I), 10-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 50i, freesync (1920X1080_50I), 8-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 50i, freesync (1920X1080_50I), 10-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994i, freesync (1920X1080_5994I), 8-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994i, freesync (1920X1080_5994I), 8-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994i, freesync (1920X1080_5994I), 10-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994i, freesync (1920X1080_5994I), 8-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994i, freesync (1920X1080_5994I), 10-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994i, freesync (1920X1080_5994I), 10-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994i, freesync (1920X1080_5994I), 8-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 5994i, freesync (1920X1080_5994I), 10-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000i, freesync (1920X1080_60I), 8-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000i, freesync (1920X1080_60I), 8-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000i, freesync (1920X1080_60I), 10-bit, RGB 4:4:4, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000i, freesync (1920X1080_60I), 8-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000i, freesync (1920X1080_60I), 10-bit, RGB 4:4:4, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000i, freesync (1920X1080_60I), 10-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000i, freesync (1920X1080_60I), 8-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 6000i, freesync (1920X1080_60I), 10-bit, YCrCb 4:2:2, Headroom
Feb 10 09:15:30 : POINTER : Trying wacom
Feb 10 09:15:30 : AUDIO : AJA
Feb 10 09:15:30 : Executing command: /bin/sh /usr/discreet/smoke_2013.2.53/bin/platforminfo
Feb 10 09:15:31 : Tooltips loaded
Feb 10 09:15:35 :
Feb 10 09:15:35 : Workstation: MacPro5,1
Feb 10 09:15:35 : CPU: 1 Quad-Core Intel Xeon @ 2.8 GHz, 4 cores
Feb 10 09:15:35 : RAM: 32 GB of RAM
Feb 10 09:15:35 : Graphics: ATI Radeon HD 5770 Driver:
Feb 10 09:15:35 : OS: OS X 10.8.5 (12F2518)
Feb 10 09:15:35 : Kernel: Darwin 12.6.0
Feb 10 09:15:35 :
Feb 10 09:15:35 : FONT : Installing links in /usr/discreet/font
Feb 10 09:15:35 : MENU : /usr/discreet/smoke_2013.2.53/menu/default.menu
Feb 10 09:15:38 : Using 1920x1178 offscreen UI rendering with window size 1920x1178 (100.0% scale factor, 1.630 W/H aspect ratio)
Feb 10 09:15:42 : POINTER : Initialising.
Feb 10 09:15:42 : POINTER : Initialising Wacom UD.
Feb 10 09:15:43 : GRAPHICS : Supported depths: 8, 10, 12, 16fp bits
Feb 10 09:15:44 : Output log to: '/usr/discreet/log/smoke2013253_prod-222_app.log'.
Feb 10 09:15:44 : AUDIO : Default directory: ~/audio
Feb 10 09:15:44 : AUDIO : Import-Export directory: ~/audio
Feb 10 09:15:45 : ProgramXilinx error=e00002bd
Feb 10 09:15:45 : Unable to load Autodesk bitfile into the AJA board
Feb 10 09:15:45 : VOLUMEMGT : Using 7 as root partition.
Feb 10 09:15:50 : Using 1920x1178 offscreen UI rendering with window size 1920x1178 (100.0% scale factor, 1.630 W/H aspect ratio)
Feb 10 09:15:56 : PROJECT : demo_temp
Feb 10 09:15:56 : VOLUME : stonefs7
Feb 10 09:15:56 : USER : FCP7_Eve_2016-12-7
Feb 10 09:15:57 : CONFIG : /usr/discreet/project/demo_temp/cfg/demo_temp.cfg
Feb 10 09:15:57 : VIDEO: monitor refresh rate detected as: 60.000000
Feb 10 09:15:57 : PROJECT VIDEO PREVIEW: Using the following parameters for the preview device:
Feb 10 09:15:57 : VIDEO PREVIEW : aja, channel 1, 1920x1080, +0, +0, 23976p, DTVsync (1920X1080_2398P), 8-bit, YCrCb 4:2:2, Normal
Feb 10 09:15:57 : PROCESSORS : 8 available
Feb 10 09:15:57 : Could not test existence of process 9379 on host 10.10.2.200:
Feb 10 09:15:57 : DLmpd daemon on 10.10.2.200 is not responding.
Feb 10 09:15:57 : Could not test existence of process 9611 on host 10.10.2.200:
Feb 10 09:15:57 : Could not test existence of process 10260 on host 10.10.2.200:
Feb 10 09:15:57 : Could not test existence of process 11110 on host 10.10.2.200:
Feb 10 09:15:57 : Could not test existence of process 11291 on host 10.10.2.200:
Feb 10 09:15:57 : Could not test existence of process 27271 on host 10.10.2.200:
Feb 10 09:15:57 : Could not test existence of process 27646 on host 10.10.2.200:
Feb 10 09:15:57 :
Feb 10 09:15:57 : VOLUMEMGT : Framestore integrity check not needed...skipped.
Feb 10 09:15:58 : VIDEO : width: 1920, height: 1080, pixelFormat = 10-bit, timing: 1920X1080_2398SF
Feb 10 09:15:58 : MEMORY : Bytes available: 29327 MB
Feb 10 09:15:58 : MEMORY : Using 3000 MB (or 189 buffers of size 1920x1080 @ 10-bit).
Feb 10 09:15:58 : MEMORY : Allocated 3000 MB at address 0x1c4a8e000 using memalign()
Feb 10 09:16:03 : ProgramXilinx error=e00002bd
Feb 10 09:16:03 : Unable to load Autodesk bitfile into the AJA board
Feb 10 09:16:10 :
Feb 10 09:16:10 : EDL Module: Portions Copyright 1991-1998 ALBA Editorial, Inc.,
Feb 10 09:16:10 : All Rights Reserved.
Feb 10 09:16:10 :
Feb 10 09:17:43 : Invalid server id ':0' with storage id ''.
Feb 10 09:18:17 : Invalid server id ':0' with storage id ''.
Feb 10 09:40:35 : Header for /usr/discreet/clip/stonefs7/demo_temp/workspace.smoke_F33FB6BF-0571-400E-8B72-E58BEFE239EF.wksp/_Export_170210_091834_1.000.clib cannot be read or is incompatible.
Feb 10 09:40:35 : [VREF]:ERROR - Failed to obtain frame references from /usr/discreet/clip/stonefs7/demo_temp/workspace.smoke_F33FB6BF-0571-400E-8B72-E58BEFE239EF.wksp/_Export_170210_091834_1.000.clib
Feb 10 09:40:35 : Invalid server id ':0' with storage id ''.
Feb 10 09:43:28 : Application: smoke 2013.2.53 x86_64
Feb 10 09:43:28 : Pid: 954
Feb 10 09:43:31 : Uninitialising thread manager.
Feb 10 09:43:33 : 2017-02-10 09:43:33.911 senddmp[9765:807] *** CFMessagePort: bootstrap_register(): failed 268435459 (0x10000003) '(ipc/send) invalid destination port', port = 0xb117, name = 'com.apple.coredrag'
Feb 10 09:43:33 : See /usr/include/servers/bootstrap_defs.h for the error codes.
Feb 10 09:43:33 :
In backbunner.
  • Certain jobs have been suspended( see screenshot 001 attached) with the following error: prod-222 [error] 0 transcoderAdapter.C:621 02/08/17:14:29:17.669 Current task is not responding.
  • Other jobs remain active but are waiting for the server to starter but all info on the service monitor are green and have been restarted successfully (see screenshot 003 attached).
  • I have a duplicate of prod-222 (see screenshot 002 attached)
Computer Specs.
Software:  OS X 10.8.5 (12F2518)
Model Name: Mac Pro
Model Identifier: MacPro5,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 2.8 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 32 GB
Processor Interconnect Speed: 4.8 GT/s
Boot ROM Version: MP51.007F.B03
SMC Version (system): 1.39f11
SMC Version (processor tray): 1.39f11
Other information.
The MAC hasn't been upgraded for sometime now.
AJA Switch hasn't been updated for awhile either.
If you need anything more, tell me.
Cheers,
2 REPLIES 2
According to the information you shared, the export issues you encountered are definitely not related to the same root cause (some seem to be related to stone+wire configuration and some other might be related to the location of the media on disk).
There is no magic solution here and each of them will have taken one by one and investigated separately.
As you understand, this is something that can hardly be done through a discussion forum.
If you are current on subscription, I strongly suggest you to open a case with our technical support team so one of our engineer can have a look and see what it going on.
Yann
Yann Laforest
Program Manager Data Analytics - Autodesk EMS
10 rue Duke Street
Montréal (Québec) Canada H3C 2L7
Hello Yann,
Thank you for your response, that's what I feared. Not that I expect a magic solution, but pointers to where we should look and investigate. Being a beginner in Smoke and taking over the software and drive without the previous editor with me, I have to admit that my knowledge is very small on the matter. I'll try to see what I can do about the media on disks.
As for our subscription, we have no idea, the IT manager is currently on sick leave, hardly reachable and if we want to get any information to be able to contact your Technical Support team, we'll have to wait until Wednesday, another former member of our team is coming to give us a hand on various mater, will present him with our issues and ask about the possibilities of contacting your team.
Thanks again for your quick response,
All the best,
