Dear Autodesk Support!
We recently reformatted our iMac with the intent to set it up for the new Smoke 2017 Version.
Setup as follows:
iMac5k 64GB RAM
OSX Sierra (latest Version)
Blackmagic Video Driver 10.6
Smoke 2017 Update1 SF1
Everything seemed fine first when we received this on the second startup:
DLMPD: Warning,Multi-Purpose daemon not responding, please exit Smoke and restart the Multi-Purpose daemon using the service monitor.
All Services Green in Service Monitor, after restarting the daemon the error still showed up on start. (same on reboot)
Curiously if you just ignore the error and keep working in Smoke without a restart it seems to work. The message still pops up occasionally once in a while. (whenever it seems to check on the shared libraries, sometimes the check passes with no error)
What we tried so far:
checked the whole network stack, assigned fixed IP, setup a clean machine name and entered it to the hosts file, everything resolves correctly.
the error still shows up radnomly after these adjustments but curiously less often.
this is what the smoke log is showing:
[notice] 2751984576 messageAccumulator.C:520 01/19/17:16:43:39.467 PROJECT : Initialising.
[notice] 2751984576 dlnfs.C:166 01/19/17:16:43:39.469 Connected to DLmpd on 127.0.0.1
[notice] 2751984576 projectUtils.C:7798 01/19/17:16:43:39.470 PRJMGT : User list build completed ( took 0.00 sec )
[notice] 2751984576 projectUtils.C:3859 01/19/17:16:43:39.470 PROJMGT : User "mike_R_2017" is compatible.
[notice] 2751984576 dlnfs.C:166 01/19/17:16:43:39.474 Connected to DLmpd on 192.168.3.20
[warn] 2751984576 dlnfs.C:156 01/19/17:16:43:39.479 Cannot connect to DLmpd (Sys ) on host 192.168.3.38
[warn] 2751984576 dlnfs.C:156 01/19/17:16:43:39.491 Cannot connect to DLmpd (Sys ) on host 192.168.3.34
[notice] 2751984576 dlnfs.C:166 01/19/17:16:43:39.494 Connected to DLmpd on 127.0.0.1
[notice] 2751984576 projectUtils.C:7187 01/19/17:16:43:39.495 PRJMGT : Project list build completed ( took 0.00 sec )
[warn] 2751984576 prjHost.C:1227 01/19/17:16:43:39.496 Could not get last modified time of '/opt/Autodesk/clip/stonefs7': No such file or directory
[notice] 69287936 CoMsgLogger.cpp:215 01/19/17:16:43:39.509 Last entry repeated 2 more times.
[notice] 2751984576 log.C:373 01/19/17:16:43:39.509 Metadata streaming buffer: 0 MB ==> 1850 MB.
[warn] 2751984576 CoNetworkLocal.C:100 01/19/17:16:43:39.515 locale CTYPE is 'C'
[warn] 2751984576 prjHost.C:1227 01/19/17:16:43:39.521 Could not get last modified time of '/opt/Autodesk/clip/stonefs7': No such file or directory
[notice] 69287936 CoMsgLogger.cpp:215 01/19/17:16:43:39.528 Last entry repeated 2 more times.
[notice] 2751984576 menu.C:7187 01/19/17:16:43:39.528 PUSH MENU : Main to MainProjectUser
[warn] 2751984576 prjHost.C:1227 01/19/17:16:43:39.529 Could not get last modified time of '/opt/Autodesk/clip/stonefs7': No such file or directory
[notice] 69287936 CoMsgLogger.cpp:215 01/19/17:16:43:51.781 Last entry repeated 3 more times.
[notice] 2751984576 messageAccumulator.C:520 01/19/17:16:43:51.781 DLMPD : Warning, Multi-Purpose daemon not responding, please exit Smoke and restart the Multi-Purpose daemon using the service monitor.
[error] 2751984576 program.C:411 01/19/17:16:43:51.781 Could not connect to DLmpd module "Sys" version 1.08.00.
Either DLmpd is not running or the required plugin module (Sys v1.08.00) is not installed.
You can verify which DLmpd modules are installed on your system with the following shell command:
pkgutil --pkgs | grep com.autodesk.dlmpd
To start DLmpd:
1- in a shell, login as root;
2- execute "/opt/Autodesk/lib64/DLmpdctl restart".
[notice] 2751984576 menu.C:7187 01/19/17:16:43:51.786 PUSH MENU : MainProjectUser to DialogBox1
[notice] 2751984576 menu.C:4373 01/19/17:16:45:01.675 BUTTON : [Close] AnswerDialog(0)
[notice] 59641856 CoThreadPthread.C:289 01/19/17:16:45:01.818 Registered thread 'Server Task' [ 123145361952768 ]
[notice] 2751984576 menu.C:7115 01/19/17:16:45:01.818 POP MENU : DialogBox1 to MainProjectUser
[warn] 2751984576 prjHost.C:1227 01/19/17:16:45:01.837 Could not get last modified time of '/opt/Autodesk/clip/stonefs7': No such file or directory
[notice] 2751984576 menu.C:4378 01/19/17:16:45:03.667 BUTTON : [Start] PrjLoadFirstSelection
[warn] 2751984576 prjHost.C:1227 01/19/17:16:45:03.668 Could not get last modified time of '/opt/Autodesk/clip/stonefs7': No such file or directory
[notice] 2751984576 log.C:373 01/19/17:16:45:03.675 Metadata streaming buffer: 0 MB ==> 1850 MB.
[notice] 69287936 CoMsgLogger.cpp:215 01/19/17:16:45:03.682 Last entry repeated 1 more times.
[warn] 2751984576 dlnfs.C:866 01/19/17:16:45:03.682 Sys.symlink('192.168.3.20:18257', '/opt/Autodesk/user/mike_R_2017/tmp/user-lock') failed: File exists
[warn] 2751984576 dlnfs.C:884 01/19/17:16:45:03.682 symlink('192.168.3.20:18257', '/opt/Autodesk/user/mike_R_2017/tmp/user-lock') failed: File exists
[user] 2751984576 FuFileLock.C:511 01/19/17:16:45:03.685 PID 18257: Removing lock "/opt/Autodesk/user/mike_R_2017/tmp/user-lock" held by dead process (7AE36170-99B6-47B1-9AB0-627EAD45B906:smoke-2017:192.168.3.20:1863)
[notice] 2751984576 project.C:6107 01/19/17:16:45:03.685 PRJMGT : Project (_test_2017)
[notice] 2751984576 project.C:6108 01/19/17:16:45:03.685 PRJMGT : Volume (stonefs)
[notice] 2751984576 project.C:6109 01/19/17:16:45:03.685 PRJMGT : User (mike_R_2017)
[notice] 2751984576 services.C:417 01/19/17:16:45:03.688 service "IFFFS": have 2017.0.2, want 2017.0.2
[notice] 2751984576 services.C:417 01/19/17:16:45:04.014 service "Gateway": have 2017.0.2, want 2017.0.2
[notice] 2751984576 services.C:480 01/19/17:16:45:04.015 Service "IFFFS" is OK
[notice] 2751984576 services.C:480 01/19/17:16:45:04.015 Service "Gateway" is OK
[warn] 2751984576 CoNetworkLocal.C:100 01/19/17:16:45:04.020 locale CTYPE is 'C'
[warn] 2751984576 prjHost.C:1227 01/19/17:16:45:04.021 Could not get last modified time of '/opt/Autodesk/clip/stonefs7': No such file or directory
[notice] 69287936 CoMsgLogger.cpp:215 01/19/17:16:45:04.054 Last entry repeated 1 more times.
[notice] 2751984576 messageAccumulator.C:520 01/19/17:16:45:04.054 VOLUMEMGT : Initialising volume 'stonefs'
Running pkgutil --pkgs | grep com.autodesk.dlmpd yields the following:
com.autodesk.dlmpd.admin.sw.base.1.2.x86_64.pkg
com.autodesk.dlmpd.core.sw.base.x86_64.pkg
com.autodesk.dlmpd.sys.sw.base.1.8.x86_64.pkg
com.autodesk.dlmpd.volume.sw.base.1.3.x86_64.pkg
running execute "/opt/Autodesk/lib64/DLmpdctl restart" seems to have no effect.
i am out of ideas here on my part, any input would be greatly appreciated!
thanks a lot!
Solved by jaseo. Go to Solution.
still brainstorming over this. new theory. Is Smoke 2017 trying to connect to other daemons on the network?
We have two other but barely used installations of Smoke 2015/2016 running on those IPs. Could the error actually point to those daemons and not the local ones? This could also explain why the 2017 installation seems to keep working if you just "close" the error message.
we will uninstall/shutdown the two other machines tomorrow to test this.
will report with results.
(sorry for the double post if a mod could remove the duplicate i got a forum error on first attempt, thank you!)
This is a bug with dlmpd and Sierra. It's been fixed in the latest versions of flame, so the fix should be in the next smoke update.
cheers
Hello, we have the same problem. Do you know when a new update will appear. Or biggest problem with this bug is that our Smoke 2017 don't let us archive our projects. How we can solve this problem until don't appears a new update?
Thank you for your attention!
The issue you are referring to was addressed in Smoke 2018.
Are you still experiencing the issue in Smoke 2018?
Yann
