Is it possible to add my own custom tokens to those available as standard in the Media Export window?
if so...how?
thanks
Adam
Solved by fred.warren. Go to Solution.
Hello Adam,
No, it is not possible to add custom tokens.
fred
Hello @julioleon,
I don't think there is a chapter dedicated to the tokens in our current documentation. I think it is spread into separate parts where tokens can be added.
Is there anything specific I could help you with?
fred
Where specifically can tokens be created and modified?
Rob Holmes
------------------------------------------------------------------------------------------------------------------------------------------You can now use a custom index token. For example:
StarWars_SubTitle_R1_<index####@10+10>_v001
StarWars_SubTitle_R1_0010_v001
