Modeless document / folder moving in Gallery view
If you long-press a document, it expands and you can drag it. But you can't drop it in an album folder. Instead, you have to first go into a select mode, then select the item, then press "move" at the bottom, and then, finally, drag. Why all of these pointless extra steps, when just drag and drop from the base screen is intuitive and already partially implemented?
