Layers options
Layers options
You know how there is an option in your Layer Settings to erase all hidden layers, well, to put it frankly, it causes more problems than it solves, because I normally hid a LOT of layers, this setting erases a lot of my progress, and the worse thing is that is just beside the fuse all visible layers option, which, because I use a lot, causes me to accidentally press that option
My suggestion is that you either add a "are you sure?" after you press it, or you erase that option completely
