Layer blend modes swapped when exporting
There is just one layer on my drawings sometimes that, if I set it to Color Dodge and export the image, it saves as the appearance of Glow; if I set the layer to Glow, it saves as the appearance of Color Dodge.
All other layers are working fine, but this single layer does this swap.
I’ve tried duplicating the layer and deleting the original but no difference. I’ve restarted the app, opened and closed the drawing, etc. I’ve had this issue many times in the past and usually could only fix it by redoing the entire layer.
1 Comment
I’d like to clarify, this is in the IPAD app.
