I am sure there a re plenty of individual posts that share some of bellow, but here is my list ans I hope you can pin this to the developers wall and keep as a reference.
- Dark theme ( Just like Adobe software have shifted to dark themes, would like to see sketchbook boss version to have this feature).
- Tabs (like autocad, photoshop, illustrator, etc,. to have tabs, so I can have multiple sketchbook files open at the same time, very frustrating, currently have both desktop and windows 10 app so can open max 2x files).
- Grid (an absolute must! Currently I have a template shoved under each new file, it is not sharp when zoomed in because of the resolution, so an integrated grid, which lets us set increments in cm, mm, inches, kilometers etc!)
- stackable (sticky) panels (just like in photoshop or any other software you can stack full height tabs, currently I try to expand layers to full height of the screen on my Mobile Studio Pro but it only goes so high, and leaves a section at the bottom where I shove Color and Brush pucks underneath. )
- speed, speed, speeeeeeeeeed!!! (the software has a lag when zooming in, or selecting tools, navigating through layers, crop, rotate, move etc,. needs to be improved, just like the apps for windows 10 or android have a buttery smooth experience.)
- swatches (further improvements needed, currently there is a box of 4x6=24 (swatches) so a way to import or add, edit, group, delete needs to be implemented.
- layer picker tool (very counterproductive is to be working on a file with dozens of layers and going through the list and trying to find on which layer does the sketch sit, by hitting eye (on/off) there should be a quick access tool (in the right click menu) that lets you jump in the layer by picking a line, texture, surface in the sketch - just like Photoshop when you right click it tells you have many layers overlap and you can select one.)
- blending modes (a quicker way to go through blending modes in the layer stack, a preview as you choose which to use (like photoshop again example) or a custom shortcut.
- right click round wheel (could we have more icons available? Currently there are 8, or maybe a section in preferences, where you can specify max 12 icons etc,. I feel I could do with couple of more tools in this handy wheel.)
_________________________________________________________________________________________
Things I love and would appreciate if left intact or improved (speed)
- stability of the software (I work a LOT on Sketchbook Pro and it has crashed only handful of times)
- built in file recovery (Like how, if the software does crash, upon opening it nicely recovers the last file. Does display all the layers in one mess, but not an issue for me if I know that the file is preserved.)
- Perspective tools (nailed it! So simple to use, the lock, hide, is fantastic experience to use these tools, I have seen grids on android and further improvements, do think grids should be a checkbox as can get distracting, simple lines are great)
- The Puck (when holding space brings up this zoom/rotate puck, such an intuitive idea. At the beginning was struggling but now comes like second nature, great feature!)
The smoothness and I guess "lightness" of the feel, when you navigate, use tools and responsiveness is a key to make this a great product.
This covers it at the moment. I just want to let you know the features I think are crying out to be added in the new version of Sketchbook pro 2020, the real 2020, cant wait for this critical version to come out soon!!!
