sketchbook para windows 7 32 bits
necesito que me brinden sketchbook para w7 en 32 bits, porque lo que encuentro es solo 64 y no me funciona
david.lau
Download this version:
https://myshare.autodesk.com/:u:/g/personal/david_lau_autodesk_com/ERVxJdbDCRxCluGGpIZVxKQBbJtLOunLr...
Sign in (same one as the forums)  and you will be able to use it or 100 years.  DO NOT BUY IT!  The store fronts are 'closed' and will error out.
David Lau
Link doesn't work
