I'm trying to log in to sketchbook so I can upgrade to pro, but for some reason sketchbook is telling me I can't access the internet, even though my internet access is working fine.
I've downloaded and deleted this program multiple times and still run into the same problem. What might be wrong?
Solved by d.bosley. Go to Solution.
1. Find a 'spare' computer and install SketchBook from here: www.sketchbook.com/thankyou
2. Try to Login on the 'spare'computer, if the login works - GREAT.
3. After logging in, make sure that you are in Pro mode or in 90 day trial.
4. Start > Regedit.exe
5. Navigate to: Computer\HKEY_CURRENT_USER\Software\Autodesk\SketchBook
6. Export the key.
7. Copy key or zip it (Send to Compressed Folder) to USB drive.
8. Run .reg file on ýour çomputer that can't login.
When you perform a 10.13 upgrade, you will need to backup your your computer. Most notably the /Users/USERNAME (house icon)/Documents folder. Do a straight upgrade (keeping the files) will not solve the issue. You need to do a clean install of the Mac OS. You will need to bring up the Disk Utility just before installing it and reformat the drive before installing the the update.
1. Download Mac OS Sierra and/or High Sierra
2. Get a 8 GB USB drive and make a bootable USB. Harder https://support.apple.com/en-ca/HT201372 Easier http://diskmakerx.com
3. Boot on USB (holding OPTION key) and Wipe drive then install Mac OS 10.12/10.13.
I have recently done this on 2 computers and I have found out it's really hard to make a High Sierra Bootable drive so the workflow is as follows:
1. Backup contents (Copying files can take up to 8 hours) or use Time Machine (longer)
2 Download Sierra.
3. Download Disk Marker and make bootable USB with Sierra.
4. During install of Sierra (10.12), you must format drive to it's empty.
5. Right after installing Sierra, run update to get High Sierra.
6. Install SketchBook and Apps. Login will work.
7. Copy files back to your computer.
Are you serious? This is not an acceptable fix. Backup my data and wipe my OS to fix a login bug on a free app that I've never needed to login to before? Lol. No.
Additionally, after 2 months of effortless functionality, I just got this SKB bug on my iPad Pro. What's the fix when I don't have access to a bootable USB drive since it's an iPad and has no USB ports?
I was really enjoying the flow and interface of SKB but blocking bugs like this, on a free app, are egregiously frustrating. (Well, to be honest, I'd be more pissed if I actually paid money for it.)
Also, did I just lose all my illustrations if I didn't convert them to PSD's?
I guess I'll be moving on to procreate. ¯\_(ツ)_/¯
Not luck here either, not on W10 or W8. At least on W8 it did show the login menu (which appears completely blank on W10) with a script error notification popping up, but after typing in my email and password it shows an error saying the page isn't available.
You need to have IE 11 installed on your computer. You can also try installing it on another computer and use the Registry key hack. (See Above).
I completely agree that this is not an acceptable fix- especially for paying users. I'm sick of opening tickets with these guys only to be ignored.
Procreate you say? I'd rather pay a bit of money for something that works instead of no money than jump through a windows update-- which I just did a few months ago.
I'm in costumer service- and this decision to tell all the people to update windows is a joke.
As mentioned above, installing bloatware to be able to use Sketchbook on PC isn't a valid solution. I'll have to look for alternatives outside of Autodesk.
Thanks David! Kiss on your cheek. Your solution worked for me with my Win7 sys. After rebooting though. Started Sketchbook - only had to hit the Sign in button in the login screen and voila! Best regards from Trudy.
I had the same issue on Windows 7 after I needed to format the hard drive for something else. It took me a few hours of figuring it out, but what finally worked for me was to open Internet Explorer 11 and to change its security options to 'Medium' (the default) and the privacy settings to 'Accept All Cookies'
I hope this helps.
