Sketchbook 8.6 for 32Bits
Hi i want to download the latest sketchbook update from the page and i can't see the 32bits installer, how i can install it?
PD: thanks for the help
Replies (22)
david.lau
It is not available anymore.  You need to get a 64 bit computer.  I wrote this blog post a long time ago to explain what 32 and 64 bit means....
http://upandready.typepad.com/up_and_ready/2011/09/general-systems-what-is-the-difference-between-32...
David Lau
Ridiculous.
If it's free, they could simply enable the paid functionality for all users who have the 32bit version installed... same as they would have when they were accepting payments for it. They could trivially still host the last version of the installer.
If they they no longer want to support the 32 bit version, they could say this, and let their users have it with the understanding of no further support for it. Lots of people have 32-bit Windows tablets.
The adage is that if the product is free, then the user usually IS the product; note how the "free" 64bit version demands a login. This would allow them to monetize the size of their user-base, with an always accurate count (as of the last seven days).  If it was truly free, then they wouldn't care about the login—or revoking access to the 32-bit version.
А как быть с теми у кого планшет поддерживает только х32? Разве нельзя оставлять последнюю актуальную версию программы под х32?
david.lau
This is our last update for 32 bit.
https://myshare.autodesk.com/:u:/g/personal/david_lau_autodesk_com/ERVxJdbDCRxCluGGpIZVxKQBbJtLOunLr...
There is no need to buy it.  Just sign in and it should work....
David Lau
I have facing dll issues , I mean missing api-ms-win dlls.
david.lau
@Anonymous You need to upgrade to Windows 10 or run a full Windows update on Windows 7.  NOTE:  You may need to run the Windows update several times.    It is the only solution to your issue.
David Lau
stepalatisJWARL
@david.lau Hello, thanks for sharing this version, I've been using it on my 32-bit system (unable to run the 64-bit system) for quite a time.
However, a few days ago the app got a problem, it does not connect to the internet anymore, to unlock Pro features. Is there any chance that this app will get an update? Thanks in advance for any help.
Здравствуйте, х32 больше не обновляется и не поддерживается разработчиком. Только х64. Но на windows х32 вы не сможете установить х64, так как х32 не поддерживает 4gb оп.
Вам могу посоветовать удалить и переустановить sketchbook 8.6 x32.
У меня эта же версия стоит и все работает. Проблем с интернетом нет.
stepalatisJWARL
@Anonymous Thank you for your kind advice. But I have tried many things, including this one. Now it just seems like the app will not ever run properly. Now I'm trying to find out if the problem is in Windows update. If you are using Windows 10, would you please check in "update history" in your device, if there is the update "KB4556799"? Thank you.
Я использую, на планшете, windows 8.1
Могу, чуть позже, скинуть установочный файл, который у меня установлен.
Может с ней у Вас не будет проблем.
Если проблема сохраниться, то остаётся переустановка windows
stepalatisJWARL
@Anonymous I'd be happy for that, thank you. Yes, I was considering reainstalling windows too, but I have that as my last option, because that is a little bit complicated in my situatuion.
Ссылка на скачивание SketchBook_pro_8.5.1.0_Win32
https://drive.google.com/open?id=148dGmsyQ1yWxyb_5i3IrtvAWj9nFzQmuСнимок экрана (20).png
stepalatisJWARL
Thank you, Garik. So I thought the installer would be the same as mine, but it behaved a little bit differently. I could log in, at least for the first time. Then I closed and reopened and there was just a trial version again. But at least it gave me a little hope, so thank you!
Так и будет, при каждом входе пробная версия, нажимаете на версию pro и у вас снова pro версия. Рад был помочь 🙂
Hello! I'm also using the 32bit-version on my tablet with win10-32bit. Till yesterday it worked normal with all profeatures. Now I get the message, that the prog can't connect to the server https://accounts.acg.autodesk.com
What ca I do to solve this problem?
Regards Rebecca
I am having the exact same problem, if any one PLEASE i need this urgently
a similar situation while looking for a solution. support is silent.
It's looking very bad guys. I've got a response by private mail. They told me, that "the web services is going under maintenance mode" and "We don't have an ETA on when the web services are going to be back up again.  I am sorry to tell you that.  The only way to get SketchBook running is to move up to a 64 bit OS/Computer.  The latest version does not have a login component at all".
So it seems, that all people who run 32bit-OS are thrown out for ever because they don't support them anymore!
Regards Rebecca
Exact same problem with me as well, 32 bit processor running sketchbook pro 8.5 and cannot login.
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
