Moving Files into Other Folders
Hello. I just finished a sketch, and I want to move it out of the default "Untitled folder" and into another folder. Is there a way that I can do this, or are all files stuck in one folder?
I am using an Android tablet.
david.lau
1. Select Image.
2. Hold on image for 1-3 seconds and there will be an "animation' that something is happening.
3, Tap hold to drag into new folder.
All sketches are local to the device. You need to back it up manually:
On Android, it's pretty easy, just copy the files from /Autodesk/SketchBook3 and copy it to your desktop computer. You can use the desktop version of SketchBook to complete our work (www.sketchbook.com/thankyou)
To re-import the file, you need to do this:
https://www.sketchbook.com/help/knowledge-base/back-files-settings/
See:  How to import SketchBook files from an older version into the latest version SketchBook for Android
To save a copy or version a file on the Mobile platform:
a. Start Sketch
b. Go to Gallery and start a new Sketch, It will ask you to save the file.
c. Go to the Gallery and start a new Sketch again and it will ask you to save the file.
d. Open the first Sketch and work on it.
e. Go to Gallery and start new sketch and choose the "Save as a Copy" option.
David Lau
i tried this, but it keeps not going in the folder and then the hold down option is stuck so i cant interact with the whole app until i restart my tablet. This only happens with AutoDesk Sketchbook app. I try to move drawings to another folder and it just hovers over it then goes back, and is jammed until i restart it, whether or not i close the app and re-open, it stays jammed and unresponsive.
Same exact issue. I have a Lenovo ChromeBook btw.
