Recently when I try to add a layer or delete it (or basically any function that involves to manipulation of the layers)
it freezes for a really long time and crashes completely. I have tried uninstalling and reinstalling again and also reset it multiple times but it doesn't work
Solved by david.lau. Go to Solution.
The Windows 10 app doesn't work anymore since the last update. We don't know if they work on a quick patch for that since david.lau did not give real advice or infos. Just delete this or that and we tell it's not working.
See this post for more infos : https://forums.autodesk.com/t5/sketchbook-forum/ios-android-uwp-windows-store-update/td-p/8773399
