How to make existing background on imported file transparent.
I need to remove the backgrounds from product photos. Is it possible to do this in Autodesk Sketchbook? Would it help to take the photos on a blue or green background instead of a white one?  Thanks Marcia C.
david.lau
Try this as a test.
1. Create a circle and fill it in as black.
2. Click on Background and make it checkered (Background will save a transparent).
3. Use "Save" > Format *.tif (so you save your layers).
4. Then "Save As" > Format *.png (so it will have a transparent layer).
5. Import into another App like Illustrator, PowerPoint, Word etc and the background will be transparent.
David Lau
Thanks David!
Marcia
