How to hide ALL the UI
rgBUKK3
rgBUKK3
With Sketchbook for iOS (on iPad, with Pencil) is there a way to hide all the UI, such that I could sketch right next to the edges of the screen without inadvertently triggering e.g. the marking menu?  And if so how would I unhide it again later 😀?
The Rapid UI is super nice, but even it gets in the way sometimes.
Replies (7)
david.lau
To remove the double puck,  go to bottom middle section.
To hide UI, thee last icon on the top,
David Lau
rgBUKK3
When one clicks the last icon on the top, that hides most of the UI, there is still some UI that gets in the way of sketching:
1. the marking menu button at bottom middle section
2. the rapid UI at left or right
3. the button that brings back the full UI
My question is about how to hide the 3 items above, i.e. ALL the UI.
david.lau
Can you post a suggestion here:
https://forums.autodesk.com/t5/sketchbook-ideas/idb-p/804
You want to 'Hide all UI" on mobile versions of SketchBook (on Tablets).
David Lau
rgBUKK3
Done.
Hello. How did you do it? I have the same "wish".
rgBUKK3
Unfortunately, there apparently is no way to hide all the UI.  All I got "done" was to post to that other forum (at the link they provided above) a request that they add that feature.
I have the same issue. Particularly with the marking menu at the bottom. Even if we could just move it.
