How to create grids
How to create grids
How to create grids
Hey
I wanted to know how to create 3x3 grid on the canvas. Can’t seem to find it anywhere.
  I’m using sketchbook for iPad.
Thanks for for your help.
david.lau
The maximum resolution of SketchBook on mobile is 72 DPI. This means you need to sketch using the largest size possible and then scale it to to increase the DPI of the SketchBook before printing it.
https://www.sketchbook.com/help/knowledge-base/setting-maximum-canvas-size-printing-different-versio...
This means you need to use a resolution calculator to make sure you want right resolution with canvas size.
https://www.scantips.com/calc.html
To get a grid, the only way to get it into SketchBook is to import a grid from your photo gallery..
a. Search for grid using Safari.
b. Hold Image and save to Photo Gallery
c. Import image into sketch and adjust transparency.
https://forums.autodesk.com/t5/sketchbook-forum/sketchbook-4-x-updated-my-mobile-app-and-import-imag...
David Lau
This answer is not even remotely relevant to the question...
