Hi
I am a new user, working with the latest version of Sketchbook on a new iPad Pro. I did a piece for the Daily Challenge, but when I tried to submit, the dialog frame for the DeviantArt login came up, but there were no controls in the frame to enter my login info. The frame was empty. How do I save my piece locally? There isn’t an option, and I don’t want to lose this work.
thanks
ed
Solved by david.lau. Go to Solution.
1. Quit the Challenge.
2. Sketch should still be there and the UI has changed from DA to Default SketchBook.
3. Start a new sketch and save the old one.
I logged in to try this solution, but in the process, I dragged my pencil over the frame, and (I think) caused the canvas widget in the frame to move, which caused a repaint-- the controls suddenly showed up, and I was able to log in. I'm guessing that Chrome / JavaScript may have an issue with painting in new frames? Not sure.
Anyway, it's sorted. Thanks!
