Exactly what the title says. I was a pro user before the app went free, but haven't had any issues until this latest update where I can't find the "account" option that usually lives on the top bar right beside the "window". This is an issue, because when I previously used the program I had a series of brushes that were linked to my account. I've had the issue of them disappearing before, but they've always come back after I had to log in, but now I can't find the option, and I cannot log in if the prompt doesn't appear.
Solved by okaybutwait. Go to Solution.
My "My Account" option has disappeared as well. I got a notification after I opened the updated version which said that not everything would be accessible until I logged into my Autodesk account, and now I don't see how to do so.
The NEW update is completely FREE! You don't need to login anymore. 🙂
What if we want to go back to the previous version? I'm having the same issues and I had a ton of custom tools that I created a long time ago and want them back.
Copy files from the 8.0 folder to the 8.7 folder:
How do I copy files from the 8.0 version and import them into the new version?
On Windows:
C:\Users\YOUR-USER-NAME\AppData\Roaming\Autodesk\SketchBook
On Mac:
/Users/*your-user-name*/Library/Application Support/Autodesk/SketchBook
The folders are 'hidden' to move them from hidden, please follow the steps noted here:
http://help.autodesk.com/view/SKETPRO/ENU/?guid=SKETPRO_Help_sb_basics_back_files_settings_html
I also couldn’t log in and lost of old paintings! I hope that I could sign in and get my paintings back...
