A glitch, a bad bad glitch
Hey, I've used Autodesk for awhile now, and I've ran into a problem. The app when opened will close and will never open... I'm very worried about it. Please fix it if you can
david.lau
What version of SketchBook are you using?
http://help.autodesk.com/view/SKETPRO/ENU/?guid=SKETPRO_Help_sb_troubleshooting_version_autodesk_ske...
What is the exact OS you are on?  i.e. Windows 10, Mac 10.12, iOS 12, Android 7 etc.
David Lau
I am using the latest version on andriod
david.lau
Can you use an older version of SketchBook?
https://www.apkmirror.com/apk/autodesk-inc/sketchbook-draw-and-paint/
I would try these older versions:   4.1.14 then try 3.7.6.
What type of device are you running?  What Android version are you using?
David Lau
