Simulation incorrect lego
I made a LEGO block and applied 200N (~20Kg) to the top of the block. However it totally deformed. When i stand on a LEGO block irl nothing happens and ofcourse I weigh more than 20KG.
Link to LEGO piece (simulation included)":
https://a360.co/2RufeOI
Marco.Takx
Hi @Anonymous,
Please place design questions on the Design forum for Fusion 360
This is the Manufacturing forum.
@jeff.pek can you transfer this question.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
But isn't the simulation working incorrect here? I checked everything again and my design was right also the material (ABS) was right. The simulation still shows me that the block just deforms.
When I stand on a lego nothing happens to it so the simulation is just incorrect. If not could you run the simulation of 200N force and see if it works? I'm really new so it could just be me not using the simulation tool right.
tyler_henderson
Are you judging the deformation because it "looks like a lot" or are you going by the actual deformation value?
Fusion Simulation exaggerates the deformation display by default so you can actually see where deformation occurs.  In most cases, actual deformation is so small that you wouldn't be able to see it.  You can adjust the scale of the deformation display with the Deformation panel in the Results toolbar.
You should also check the Safety Factor, that's going to be a better indication of whether the block will deform permanently or break.
Tyler Henderson
Principal User Experience Designer
Yes I was indeed judging it by the way it looked. Thanks for letting me know the simulation exaggerates the deformation! 🙂
