The Simulation Mechanical Idea Board has been closed down and placed in read-only mode following a recent discontinuation announcement. Please see our supporting FAQ for more information.
using group in results + probe capabilities
I would like to be able to use the groups, defined in FEA EDITOR, also for the post processing
in the same way, on a model, when some probes are defined, it could be very useful to have the same ones on a scenario (with the same mesh) created by copying the originial one (where the probe is present)
4 Comments
Sualp.Ozel
Status changed to: Comments Requested
I understand the "groups in results" part of this request i do not understand the "probe capabilities" part Can you please clarify what you are trying to do with probes, how are they added, what is the analysis type, which environment (FEA Editor vs results)? What is the end goal?
benalain13
Sualp
When a customer makes exactly the same kind of post processing on models with different loadings (and so scenarios), and he has to post process some results at nodes, where he has placed some probes, it could be very sueful to keep the nodes and located probes for another sceanio, copied from an original one....
Sualp.Ozel
SIMMECH-3792
Sualp.Ozel
using group in results has been Implemented with the 2016 release
