Please fix the Nodal Weights dialog. It has a number of issues that make it difficult to use.
1) A better name would be "Nodal Mass" since that is what is really being added.
2) The units for Mass moment of inertia are not correct. When set to mass You get N*s^2*m which is a force unit.
When set to force you get N*m^2 which is not a correct unit of inertia. The correct unit is kg*m^2 -- a mass unit. The English
units are similarly messed up.
3) When switching unit systems the values update. However, when switching from Mass to Force units within the dialog it does
calculate the conversion. If someone enters a value and then switches the input mode the value is then wrong. This makes no sense
and certainly is not would be expected in quality software.
4) Provide an option to specify the mass moment of inertia about either the model coordinate system or the center of mass (at the node).
Currently is not clear which is being specified. The help file does not clarify this.
