The Simulation Mechanical Idea Board has been closed down and placed in read-only mode following a recent discontinuation announcement. Please see our supporting FAQ for more information.
Stress Linearization
The environment of the Stress Linearization at Simulation is currently very poor comparing it to Revit or AutoCAD configuration (such as Zoom, Pan, Rotate, Orbit tool).
Should have the same configuration of the FEA editor, at least.
Other difficulty is how to pick nodes for the SCL when they are internal to the model (at comples models, such as bridges). You can use Clipping Planes to cut the model, but there is always the right angle and the steps to cut sometimes are not well defined (maybe a control of the value of the step the plane moves) for the User Interface.
3 Comments
jcraig
I would also like to be able to set up clipping planes based on 3 points. The points may be nodes or coordinates in the model. It is nice to have the clipping plane directly lined up with the SCL to show the section and the SCL. With the current interface it is extremely dificult to do so.
Sualp.Ozel
Status changed to: Accepted
SIMMECH-3725
Sualp.Ozel
this is mostly implemented in SimMech 2017
