What unit are the modal mass participation factors
melfio
melfio
So I've found the chart that lists the mass participation in each mode and axis. What unit are the results under each axis? See picture
John_Holtz
Autodesk Support
Autodesk Support
Hi @melfio
It looks like you are not using Autodesk Simulation Mechanical software; therefore, you might need to ask the company that created the software you are using.
Otherwise, my guess is the mass participation is in units of mass.
  • What is the total mass of your model?
  • What are the units of mass in your analysis? (Remember: mass = force/gravity.)
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
melfio
Hello John.Holtz,
I am using Autodesk Fusion 360.
BR
Leo
John_Holtz
Autodesk Support
Autodesk Support
Hi Leo,
The Help page "Mass Participation Factors result" indicates the values are percent. 0% indicates that none of the mass is vibrating in the direction at that frequency; 100% indicates that all of the mass is vibrating in that direction at that frequency.
John Holtz, P.E.
Autodesk, Inc.
