Perhaps my question is very simple to answer.
I made transient stress analyses (both direct and modal). There is the limitation of numbers of curves. The max. number is 26. For 27 LC calculations failed. Even if I apply 1 LC with the number 27 they will fail.
How to change the number of LC? Is it possible?
I remember the old ALGOR and there was no limits for curves.
Hi @t.lipecki Welcome to the Sim Mech forum.
I was able to reproduce the problem. When running the analysis, the Solve Log shows this message:
ERROR - Load factor out of range 1<loadfactor<26
My guess is that the limit is hard coded (or a bug), so there is nothing that can be changed to extend it to N load curves.
I suggest that you use an MES analysis. In the Element Definition, set the "Analysis Type" to "Small Displacement", and it should behave very similar to the transient stress analysis.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Hi @t.lipecki
Just wanted to follow-up to see if you tried an MES analysis, or if you have any other questions.
Thank you for fast answer. I remember times when the load curves were not limited :). Anyway I will switch to MES. I will write here about my achievements.
