T2135 Error when running Nastran from Simulation Mechanical 2016
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a simple cantilever beam with one end fixed. The other end has tensile force applied. If I try to run simulation using the Nastran solver, there's "FATAL ERROR T2135: UNABLE TO GENERATE SURFACE CONTACT USING SPECIFIED PARAMETERS" error and EXECUTION TERMINATED DUE TO DISPLAYED ERROR(S) in Summary information but the simulation finished successfully. At the end of Summary infomation is written that EXECUTION TERMINATED NORMALLY.
If I export the file to Autodesk Nastran Editor (Export - Autodesk Nastran Editor) and try to run it, it fails because of FATAL ERROR T2135: UNABLE TO GENERATE SURFACE CONTACT USING SPECIFIED PARAMETERS.
My model is very simple (see the attachment) and there should be no need to generate surface contacts.
Do you have any advice? Thanks.
Martin
