Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
suggestion reg mesh size
3 REPLIES 3
414 Views, 3 Replies
In my work, I am required to perform FEA on really long parts and assemblies.say 100 feet hollow square sections  with cross section width 50 inches.And the plate thickness would be 1 inch.so they are really long and thin parts.
Solid meshing is considered.
so my question is there any good rule of thumb to get right mesh size.How many elements would be good across thickness of the plate?
In the above example of cross section if I get min of 3 brick elements thick, the no. of elements would be enormosly large which my comp cannot deal.
any thoughts?
any thoughts?
3 REPLIES 3
20-node bricks used with 2 x 2 x 2 quadrature deal with thin structures quite gracefully.  A single element through the thickness may well be enough.
Petr
Petr
John_Holtz
John_Holtz
Autodesk Support
Autodesk Support
Or use plate elements.
John Holtz, P.E.
Global Product Support
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
John Holtz, P.E.
in reply to: John_Holtz
john
as Petr mentioned, does so many number of solid elements along thickness doesn't matter much  reg sensitivity of results?
john
