- Mute
- Permalink
- Report
Hello all,
Trying to run (what I would think) is a simple tipping analysis in MES with nonlinear material models. Scaffolding sitting on a slab, using a prescribed displacement to lift one side up so two feet will come off the ground while pivoting on the opposite two feet. At one point I was able to pull up on the one side but it acted as if the feet were bonded to the slab. All contacts are surface contacts with friction. I've tried both low & high speed contact. I've tried automatic, surface surface, point surface, point point contact types. Now everytime I try to run an analysis it won't even start & gives me a bright red "analysis failed" at the top of the design scenario tree. Whenever this happens I have to import the model from Inventor again & start over. Eventually the red failure note will appear again. It's like the file gets corrupted after so many times changing settings & rerunning the analysis. This should be a simple analysis correct? What am I missing? See attached.
I appreciate any/all help!
