Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Shaft rotation
5 REPLIES 5
Dan_Margulius
880 Views, 5 Replies
Shaft rotation
Hello All,
I would like to see my shaft rotate 🙂
I am talking about MES and on the left side of the model i have Moment applied.
On the right side of the picture i applied nodal displacement. The anlysis should run 2 sec.
Right now nothing happens on solve it just jumps to result and thats it.
ASM2013.jpg Thank you
Dan
5 REPLIES 5
So it appears brick element cant rotate...
I changed the element type to pipe but now i get a very weird error:
Design scenario : 4
Analysis type : Mechanical Event Simulation (Accupack)
Start time : 2012/06/28-23:11:46
--- Get one active element part from fem file
--- 2 enabled L&C groups are defined
--- Get 61896 points defined in range [1, 62081] from fem file
Calling the Surface Topology Generator (tsx2tsy)...
tsx2tsy: Update part surface contact/bonding data (duration=0 sec.)
--- No mid-side node required
Set up FEM points and B.C. by connected elements...
In working on FEM file or outputting ESH file
Terminal Error: FEM2ESH#59
FEM_ERROR_NO_1D_ELEMENT 3
2012/06/28-23:11:46
What should I do?
Dan
in reply to: Dan_Margulius
dan
how did you apply the moment load at the end of the shaft?
Dan_Margulius
like that:
Dan_Margulius
But i can suppress it if needed for now. I may need it later because i want the shaft to rotate 300 rpm and apply bending moment in the same time.
Dan
John_Holtz
Dan,
Please see the following page in the documentation: Simulation Mechanical > English > 2013 > Help > Simulation Mechanical > Mesh Models > Mesh Overview > Contact Pairs > Examples of Contact. This should answer your question about applying a moment to a brick model.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
