I've used what I still call the bolt wizard to generate bolted connections in an assembly. I've used this tool and procedure for years AND for weeks now on this same model (creating & re-creating bolts) and I've never seen the message that I'm getting now : "K-Node Nearly Colinear" with some of the beam elements that make up all the bolted connections.
I know what that means but I don't know how to fix it, if I need to, or how I caused the situation to exist. The message does point me to the Part and the element number but I don't know how to find those specific elements (it's not all of the bolt beam elements).
Any advice is much appreciated!
Solved by marwan_azzam. Go to Solution.
Hello Bryan,
Please try setting the beam orientation for the elements in question manually by changing the surface number.
Marwan
