Hello:
My name is Javier. I am doing some steady state simulations for a Uni project and I am having a weird problem. The simulations was not good, so I tried to make a small simulation and little by litte making a more complex system, to see if I saw the original problem (with the mess, the geometry...)
What I have discover is that all seems to be good if the Cad part I introduce is not really big. I don´t know if I explain myself.
In the next picture, the height of the part is 140mm: The result with the mesh and the final analysis with a certain boundary conditions is the next (attached pictures):
The size is 158.872mb
If I put 160mm instead of the 140mm of height, the result should be similar. However it change completely and this seems to be a wrong solution (attached pictures):
The size is 480.090mb
This file is made by a 3 bodies, in a step file. The version of the software is the educational one.
I don´t know the reason of this because the mesh, the mesh size and type, the boundary conditions etc are always the same. I have check with smaller pieces and the problem is well solve. However if I try to increase some of the dimensions, the problems is solve wrong.
Is there some explanation about that? Does anyone know from where can this come?
Many thanks,
Javier.
