Just as a learning exercise I modeld a pin in a hole using 2D elements. I was successful using nonlinear analysis both with and without material nonlinearity. With linear material I got a Hertzian contact stress within about 8% of theoretical so I either did it right or got very lucky. Is there a way to do this using linear analysis? The help file says there has to initially be no gap when solving a contact problem using linear analysis. I wasn't sure if it meant between the parts in general or between every pair of nodes involved. If it's the latter than it wouldn't work for a circle in a larger hole because you would only have one pair of nodes touching initially at the tangent point. All other pairs would have a gap.
Intuitively, it seemed to me like this should be OK, especially if you could get the pairs of nodes that you expect to touch to line up. If that is the case, how do you get the nodes to line up? I've attached a screenshot where you can see that the nodes don't line up. In other words, a node on the edge of the pin doesn't have a node immediately above it (same y coordinate) on the edge of the hole. Even if doing this wouldn't make the linear analysis work I'm still curious. If I lined them up I could put in gap elements just for fun.
