Non-uniform mass warning
- Mute
- Permalink
- Report
Lately I have been receiving the following warning when running a linear random vibration analysis:
1**** RANDOM VIBRATION ANALYSIS
Warning: non-uniform mass used as uniform at node= 556
This happens only when I run the random, but not when I run the modal. The run completes and the results appear valid. It appears to happen primarily where I have an array of rigid beams from the perimeter of a hole to the center of the whole in solid part, such as for a bolted joint. These beams are added manually to the meshed solid. The warning occurs at the nodes where the beams meet the brick elements, but only for a fraction of the total number of beams modeled this way.
Any ideas about what's happening? Thanks.
Stefan
Link copied
