Hello Community,
i would like to simulate a pressing process to determine the occurring stresses and the reaction force.
That´s what I´ve done.
The next Step is to ensure that the reaction force is sufficient at different temperatures (-40°C and 150°C).
Solved by John_Holtz. Go to Solution.
Hi Tony,
Did you change the material model (under the Element Definition) to a choice that includes thermal effects? In other words, if you are using a Isotropic material, you will notice that the material properties do not include the coefficient of thermal expansion, in which case there are no expansion effects.
Hello John,
thanks for your tip. I had not considered that.
The simulations with different temperatures have worked and the results are good.
Kind Regards
Tony
