I am exposed to a problem where my structure seems to react only where my load is applied. (See attachment 1)
After many tests, I understood that I had to meet the mesh between the elements (part).
I inquired here: https://knowledge.autodesk.com/support/simulation-mechanical/learn-explore/caas/CloudHelp/cloudhelp/...lish
I have activated the automatic meeting: "Linear static stress: Setup, Model Setup, Parameters, Contact tab, Enable smart bonded / welded contact"
But that does not change anything in my results, I do not have the nodes that meet (see attachment 2).
Do you have a solution ? please
I hope to be understandable
romat1993
Solved by John_Holtz. Go to Solution.
Hi @romat1993 Welcome to the Sim Mech forum.
I see that your model is deflecting. I do not know what the model is or what it looks like in the undisplaced shape, but all of the parts appear to be connected together. And I see stress on the parts, so I do not understand what you see in the results that makes you think the analysis is wrong. (Actually, the stress is very low, correct?)
Maybe something is wrong because of the size of the model? Two kilometers long seems big for whatever this is.
Thanks you for response
Exactly ! I used MKSI system and I do my model (dwg) in mm. Here is a corrected error !
Now, Can you confirm that the nodes automatically snap together when the contact is "bonded" ?
Hi romat1993,
I cannot confirm that the parts are bonded because I do not have the model or images of the new results, I do not know what parts are in the model, etc.
But you have the model and the results, so you can confirm if the parts are bonded together.
ok thanks you !
So, I don't need to use "smart bonded" because all these elements are bonded and by default the links are bonded in "contact" in FEA Editor.
you confirm ?
Yes. Parts are bonded if the meshes match.
