Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Heat Generation FEA calculation Question
1 REPLY 1
402 Views, 1 Reply
Hello
I normally use Autodesk CFD, but I have a nice project I would like to use in Mechanical.
My question is using the heat generation function in mechanical, is it nodal based or bulk parameter based. Another way of asking if the object is generating heat and heat generation is a function of temperature, and say a segment experiences temperature change does the whole part experience the heat generation change or is it local?
Another example in case what I wrote is confusing. If I have an 800mm long bar and it generates heat, and the heat is a function of temperature. If the bar is cooled the generation will increase. Let's say under normal room convection and temperature conditions it 5 watts, (and temp is stable). If one end of the bar was cooled and our function says at this temperature increase to 10 watts, will the rest be affected by the immediate temperature change to produce 10 watts or stay at 5 watts?
Thank you;
Gary
1 REPLY 1
AstroJohnPE
Hi Gary,
The temperature dependent Heat Generation is calculated for each element, based on the average temperature of the element.
